Heads for a 95cu
Build 2002 Lowrider (carburated)
88cu to 95cu head upgrade
I am at the point where I am getting ready to bump to a 95" cu from stock 88". I need to know wheather I should get some new SE Heads and was looking looking at MVA, ACR or MCR heads. Secondly, I have noticed quite a few 110cu heads on ebay for pretty cheap, my question is would they bolt up to 3 7/8 cylinder heads? If I could get a set of these then it is possible to have a port and polish done as well. This build is not modifying the flyweel at this time. I only have about 2 to 2.5k for the whole top end job. Next year I might modify the bottom end but will have to send this out to get it done.
The rest of the build I got covered cams, carb, pushrods. I just want to know what you guys think about the heads.
As always your knowledge is appreciated.
Kody
