handlebar question
Old Jan 26, 2010 | 10:32 AM
Duckie_EMT's Avatar
Duckie_EMT
6th Gear
Default handlebar question
quick question guys... i searched for a while, but couldn't find an answer...do you have to remove/lift the tank to swap out bars? internal wired of course..
thanks again!
Old Jan 26, 2010 | 10:39 AM
rounder's Avatar
rounder
no you don't. What year bike? Access to the wire harness is different for pre 06 than 06+.
Pre 06 don't need to touch the tank... 06+ disconnect the fuel quick release and raise tank or move it back for easy access to the panel underneath.
Old Jan 26, 2010 | 03:03 PM
08fxdf43202's Avatar
08fxdf43202
thanks again!
You definitely have to lift the tank, but I think removing the tank makes the job more enjoyable; weather or not the bars are 'internal wired' or not, although I've always gone internal.
The plastic 'dickey' thing that covers the access to the underside of the back bone is easier to remove... for getting to the control plugs, and for re-stuffing them back in.
The zip tie holding the throttle cables to the side of the back bone is easier to remove, as well as the cables from the throttle body. This also makes test fitting/routing the new cables easier.
Checking the bolt tightness on all the fasteners that are under the tank is easier. The top motor mount is on the 'critical fastener' list of regular maintenance.
I guess if you’re into high speed, 'zippy-do' kind of wrenching on your bike it's not necessary to remove the tank... which isn't hard to do... and is easier to do, once you've done it.
Old Jan 26, 2010 | 03:14 PM
J-RoX's Avatar
J-RoX
+1 i am glad i removed mine. ... it opened my eyes to many different mods soon to come.
Old Jan 26, 2010 | 05:49 PM
A-10 KChawg's Avatar
A-10 KChawg
If you are interested, get a tank lift and slap that sucker on while you are there. Very cheap mod and IMO is one of the best mods I've done.
Old Jan 26, 2010 | 06:46 PM
justmejohn44's Avatar
justmejohn44
It can be done with the tank right where it is, but it is a whole lot easier and I mean whole lot easier with the tank off.
Old Jan 26, 2010 | 09:54 PM
08fxdf43202
Yea.... easier.
Old Jan 27, 2010 | 11:09 AM
Duckie_EMT's Avatar
Duckie_EMT
6th Gear
thanks for the help guys, i appreciate it. Now the thing to conquer is the wire plug/connectors, and getting them off to run the wires through the bars...
Greatscott
Nov 17, 2014 08:59 PM
gatorfrey
Aug 17, 2014 08:50 PM
AusMongrel
Jun 3, 2012 02:12 PM
rdown1976
Jan 13, 2010 10:38 PM
springerscott
Apr 24, 2007 12:28 AM
