Need rear shock advice?
Old Jan 31, 2010 | 01:01 PM
Ring's Avatar
Ring
Default Need rear shock advice?
I am looking to lower my bike and have been looking at some 11" shocks. The service manager at the Harley Dealer said buy Progressive shocks and don't get shorter Harley shocks cause they ride bad. I have been looking at Progressive 412 shocks with chrome covers. My wife rides some so should I get Heavy Duty or when I ride alone will they be too stiff. Any clearance issues dropping 1.6"? Any advice would be appreciated!
Old Jan 31, 2010 | 03:02 PM
rdondes's Avatar
rdondes
Do a search on "shock" or "shocks" - You probably won't get more than 10,000 threads.
Old Jan 31, 2010 | 03:57 PM
hell hound's Avatar
hell hound
11" progressive 412 HD shocks are brutal if you plan on doing a decent amount of riding
You shouldn't have any clearance problems though
Old Jan 31, 2010 | 04:52 PM
rounder's Avatar
rounder
ride is horrendous if you hit any bumps. Avoid your dealers advice.... go to www.worksperformance.com. Now get a set of tracker series shocks built to your weight and riding style. Contact them and talk shocks with em. You'll learn some stuff and find out they will sell their shocks a good 10-20% less than listed on their site. You can go 11" I would not go below 11.5" though.
Old Jan 31, 2010 | 05:17 PM
Ring's Avatar
Ring
Thanks for the help! I do alot of riding so I don't want it too stiff. I checked out the worksperformance website, looks like know what their doing. I'll give them a call tomorrrow. Thanks!
Old Jan 31, 2010 | 08:50 PM
MZBuckeye's Avatar
MZBuckeye
Works is an awesome company to work with. Pick up a kit for the front end while you're at it.
Old Feb 1, 2010 | 02:30 AM
grbrown's Avatar
grbrown
If you lower the rear end you inevitably end up with less wheel travel to absorb bumps and the extra weight of your wife. I hope you have a really comfortable seat for her! An alternative shocks supplier is HDF sponsor Howard of Motorcycle Metal, who builds Ohlins to your needs. You also get a discount as an HDF member!
Old Feb 1, 2010 | 03:47 AM
HarleypsychRN's Avatar
HarleypsychRN
The ride gets worse the lower you go. I had 11" shocks on mine and bottomed out going off my hill too fast and started leaking oil. Took it up to 12" and it looks good and rides so-so. Of course at my age I should put the stock ones back on and call it a day but I just take it out for bar runs with the guys. My Road King gets the majority of the work now.
Old Feb 1, 2010 | 04:46 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I have the 11" 412's...strictly for looks, can't in good conscience recommend them.
Old Feb 1, 2010 | 10:36 AM
rounder's Avatar
rounder
can't get lowered Ohlins except for one model. Imho, even though I have ohlins, works is the best bet for dropping the rear end.
