FXDL Engine Guard
Old Feb 2, 2010 | 02:28 PM
Gunkholes's Avatar
Gunkholes
Default FXDL Engine Guard
After recently upgrading to a Low Rider from a Sportster, my bride would like me to install an engine guard (so as not to risk damaging those Anniversary medallions!)
The bar on the 2005 & earlier bolted directly to the bottom of the frame. The 2006 & up bar appears to require U-bolts on each tube.
I'm wondering if anyone has attempted to remove the hiway pegs & use the pre-2006 hiway bar on a 2006 or later? I haven't been able to compare a couple of bikes side-by-side, so I don't have a clue if it would fit.
Old Feb 2, 2010 | 02:56 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's an image of a FXDL 2008 with crashbar:
I had a crashbar on my FXD2003 before I installed the floorboards:
The difference is obvious...I'm not shure if such a bar will fit to your lady's fxdl though...
If you want me to, I could make some measurements for you.
FXD2003Rider
Old Feb 2, 2010 | 03:09 PM
Gunkholes's Avatar
Gunkholes
I appreciate the reply. It appears that the upper mounting might be an issue, as well. I'll try to get up to the dealer to see if they have an older bar I could try. It appears that your 2008 used the u-bolts? I might be stuck with that option.
Thanks.
Old Feb 2, 2010 | 04:04 PM
FXD2003Rider
Thanks.
My pleasure, Vic!
The FXD2008 is not mine, I got the image from a Google search. My bike is the FXD2003.
What I've learned from the H-D P&A Catalog: '06 and later Dyna models have the U-bolt type engine guard kits which can be used in combination with forward controls.
FXD2003Rider
Old Feb 2, 2010 | 04:21 PM
Mike Horrell's Avatar
Mike Horrell
The forward frame tubes, etc. should be the same on the FXDL and FXDC so here's
a pic of how they look on my FXDC with forwards..
I don't see how the older style would fit.
Old Feb 2, 2010 | 06:59 PM
lilsahara450r's Avatar
lilsahara450r
not trying to hijack but i thought i could put this out there, if anyone who is looking at this thread who has a pre-06 dyna, i have a linby crash bar sitting around that im not gonna use. make me an offer if interested. thanks!
Old Feb 3, 2010 | 10:43 AM
Gunkholes's Avatar
Gunkholes
Thanks for the responses, guys. I took a ride over to the local dealer yesterday afternoon to do a comparison on some pre-owned bikes. The frame differences will require the later bar on my wife's '08, so I got my questions answered.
Cheers.
Markies33
Mar 28, 2019 07:21 AM
wvu6466
Apr 8, 2013 03:49 PM
nhbiker1961
Sep 30, 2009 11:08 AM
Austen
Aug 5, 2009 06:28 PM
AC62NV
Jan 26, 2009 08:29 PM
