Part # help with slip-ons
Old Feb 6, 2010 | 12:06 PM
Two Feathers's Avatar
Two Feathers
Default Part # help with slip-ons
I bought a whole exhaust system the other day to get these slipons, I like the look of the slipons but cant find any info on what they are.
I have given the part # to my local dealer and they cant find any info, so i was wondering if anyone on here might be able to help?
The part # is 80402-01
they say 80 decibles for har fxd1340/1450
I dont think they are anything special, I like the sound but they killed the performance of my stock 03 Lowrider. just trying to find info on them, Thanks for the help.
Old Feb 6, 2010 | 01:10 PM
craftsmandave's Avatar
craftsmandave
Default Too Lean brother
In many cases the slip-ons will yeald better performance that full exhaust sytems.
But in your case you must match the air/fuel mixture to accomadate your new pipes.
Old Feb 6, 2010 | 02:33 PM
ackman1968's Avatar
ackman1968
If you went from stock mufflers to these you may want to re-jet. You probably lost some back pressure and may be running lean. Is it soft on the bottom end (less grunt taking off)? Surging, hesitation or backfire? If it still pulls hard with out pinging at full throttle your main jet is probably OK. you may just need to move the needle in the slide to bring back what's been lost.
Old Feb 6, 2010 | 05:24 PM
Two Feathers
Thanks it is sluggish on the bottom and mid, but i was also wondering if anyone had a way to find that part #, I have even tried harley.com with no luck.
I figured I would need to rejet with these pipes as my bike is totally stock still.
Old Feb 6, 2010 | 09:40 PM
ackman1968's Avatar
ackman1968
That part number is most likely obsolete as the 01 at the end refers to 2001. If you're lucky someone out there still has a 2001/2002 accessory catalog and can look them up.
Old Feb 6, 2010 | 10:33 PM
badwiser's Avatar
badwiser
80402-01 MUFFLER, RR, SLASHOUT, 3.25"
http://speedsupplies.com/partslistin...00&category=HD
Old Feb 6, 2010 | 10:48 PM
badwiser's Avatar
badwiser
http://www.latus-harley-davidson.com...ber-search.asp
Product ID: 80402-01
Old Feb 8, 2010 | 11:26 AM
Two Feathers
Thanks guys, I like the look, so now to get it rejetted..
I got the entire exhaust system ( heat shields, pipes, slip ons everything for $70.00).
decent price I thought, but figured I would need a re jet.
Dixiemilker
Exhaust System Topics
Mar 2, 2014 10:07 PM
HighLiner
Nov 29, 2010 10:01 PM
roadking53
Apr 21, 2009 09:16 PM
bensonjv
Feb 18, 2007 12:50 PM
ndglider
Feb 2, 2007 08:38 PM
