Pro Pad Mini Blast 5
Old Feb 6, 2010 | 12:55 PM
MLWilson's Avatar
MLWilson
Default Pro Pad Mini Blast 5
I installed this horn today, pretty straight forward install. I extended the ground wire to get the routing I wanted. Most of the install was spent bundling the wires for a clean install. It will get your attention. It's probably 2-3 times the size of the stock horn but does not seem to get in the way. Very well made. I re-crimped the connecters before starting to ensure all where good. Mark
Old Feb 6, 2010 | 03:17 PM
EricInNCa's Avatar
EricInNCa
That's pretty cool. I haven't seen that style before. I like the finned cover although it's a bit larger that what I'm looking for. I guess if it's waaay louder than stock...Size Matters!!!
Old Feb 6, 2010 | 06:41 PM
MLWilson's Avatar
MLWilson
This will give you an idea of how much larger the Pro Pad is compared to the cowbell.
Old Feb 6, 2010 | 08:36 PM
niterider985's Avatar
niterider985
I had mine for a while and like it a lot, it gets the cage drivers attention.
slider1156
Sep 19, 2013 12:34 PM
MACHD03
May 12, 2013 07:23 PM
rklew
Nov 10, 2010 06:23 PM
Ozoneman
Nov 23, 2009 08:46 PM
Basz
Oct 6, 2006 07:38 PM
