Bike Won't Start
Old Feb 7, 2010 | 07:18 PM
St. Bob's Avatar
St. Bob
Default Bike Won't Start
My bike has been sitting idle since October. I charged up the battery and tried to start her today but I couldn't get her to start. I put gas in her, the battery is charged but when I press the starter I just get a bunch of clicks. Any ideas?
Old Feb 7, 2010 | 07:40 PM
ord sgt's Avatar
ord sgt
How old is the battery? It could be a dead cell, not giving enough to turn the starter. Also, check your ground post. Corroded? Tight?
Old Feb 7, 2010 | 07:44 PM
Wireguided's Avatar
Wireguided
check battery connections first.
Old Feb 7, 2010 | 08:00 PM
SuperFastGlide's Avatar
SuperFastGlide
check your connections, but your battery is probally toast if it went dead since october...
Old Feb 7, 2010 | 09:02 PM
Taddeoeg's Avatar
Taddeoeg
How did you charge the battery? I'm doing this from memory since its late here and we rode all day in the cool so I'm kinda tired, but most car type battery chargers have two amp settings. I want to say 6 and 2. You charge car batteries at the higher setting and bike batteries at the lower. If you use the higher setting your bike battery won't get a good, full charge.
And did you pull the battery to charge it or charge it in place? If you pulled it I'd assume you cleaned and tightened the cables when you reinstalled so that shouldn't be a problem. But if not, the other posters are correct - check connections first. Then have the battery tested.
Since its been at least three months since it ran, I'd also inspect all the wiring. May well have had a mouse or rat gnawing on things.
Old Feb 7, 2010 | 09:17 PM
Hooker 6's Avatar
Hooker 6
Clean cables, clean terminals. Slow charge battery. Or, jump it off your car, and you'll rule out everything but the battery. In the future, might want to kee it on a tender while its parked, or pull the battery and bing it inside warm and dry.
Old Feb 7, 2010 | 09:39 PM
rdondes's Avatar
rdondes
How did you charge up the battery? How did you verify that it was fully charged? If your battery went completely dead, then a trickle charger won't fully charge it.
"Filly me bony belly fomonos fobiscos" - Cheech & Chong
Old Feb 8, 2010 | 07:37 AM
St. Bob's Avatar
St. Bob
I charged the battery using a motorcycle tender set at 12 volts. I removed it to charge but it was pretty dead off the bike. I'll try charging it again at 6 volts and see if that will do any better. Right now it looks like all signs are pointing towards a new battery. My bike is an '06 with the original battery. Thanks for the help!
Old Feb 8, 2010 | 11:09 AM
kpolak's Avatar
kpolak
Sounds like the starter isn't throwing out the gear. It may just be froze up.
You may want to take the starter off, and see if everything moves freely.
Kurt
Old Feb 8, 2010 | 03:27 PM
rounder's Avatar
rounder
even if it charges up the battery needs to be load tested to be sure it works. Maybe bring to dealer... they can test and then if need you can get your new battery.
johntaylorny
Mar 15, 2016 03:10 AM
kbob2000
Aug 18, 2012 04:11 PM
Onecoldtrip
Apr 13, 2008 08:00 PM
djprey
Jun 26, 2007 12:36 PM
nardo
Apr 4, 2006 10:34 PM
