Heavy Breather Oil
Old Feb 19, 2010 | 11:47 PM
BLKBAGGER's Avatar
BLKBAGGER
Originally Posted by Lorance66
white is the presence of all color, not black.....of course this does not help the guy find his oil
I don't think if you mix all those colors you will end up with white.
Old Feb 19, 2010 | 11:56 PM
dope_man_21's Avatar
dope_man_21
Black is the absence of color, not the abundance of color (which is white)
Bbreck, I dunno what to tell you other than as said before run it using the rain sock.
Old Feb 19, 2010 | 11:59 PM
Lorance66's Avatar
Lorance66
I didn't say you could mix three colors together and get white, however white is in fact the presence of all color. If you have ever seen a prism you can see how it takes white light and separates it into all colors of the visible spectrum.
Old Feb 20, 2010 | 12:02 AM
dope_man_21
I found this online searching for "the absence of color"
Unlike the primary colors of pigment, the primary colors of light are red, green (not yellow) and blue, commonly referred to as RGB. The pigment color system does not apply to computer monitors because colors are created on monitors by adding light. RGB is an additive color system, which means that color is added to a black background. Black is the absence of light and therefore the absence of color. Secondary colors, such as cyan, magenta and yellow, are created by combining the primary colors. The color white is achieved by adding the three primary colors together in equal amounts.
Source = http://www.webopedia.com/DidYouKnow/...2002/Color.asp
Old Feb 20, 2010 | 12:45 AM
Hickey's Avatar
Hickey
I want black oil too, I've searched and searched and I dont think it exists.
.... maybe on the 'black' market
Old Feb 20, 2010 | 05:46 AM
bberck's Avatar
bberck
Looks like I may have to stay with Red
Old Feb 20, 2010 | 06:22 AM
tdshepard's Avatar
tdshepard
Unsubscribed From Forum
It's just light mineral oil. I can't believe I am reading this either. I hope everything matches on your motorcycle........
Old Feb 20, 2010 | 07:36 AM
jss1975snow's Avatar
jss1975snow
How about mineral oil and indian ink? Mix em together for black.
Old Feb 20, 2010 | 07:40 AM
lionsm13's Avatar
lionsm13
How bout K-Y?
Old Feb 20, 2010 | 12:04 PM
watchluvr4ever's Avatar
watchluvr4ever
Originally Posted by lionsm13
How bout K-Y?
Forget about K-Y, Astroglide will make you go much faster!
