xied
Old Mar 5, 2010 | 06:05 PM
jojo2dog's Avatar
jojo2dog
Default xied
has anyone ever tried just changing the o2 sensor to get a different signal to the ecm.it seems that would be a better solution if it could be done that way
Old Mar 5, 2010 | 11:53 PM
tscreener's Avatar
tscreener
You can make your own xied style signal changer cheaper and easier and you can play with different resistors and get the change you want. I have the xied got them from ebay 40.00 used. next month going with the pc v and a stage 1 air cleaner i picked up here. They did help with the heat, but not so much the performance. se stage 1 exhaust and heat is less than stock exhaust.
Old Mar 6, 2010 | 07:19 AM
ColdCase's Avatar
ColdCase
I don't think you will find O2 sensors with different voltage ranges beside the Wideband and narrowband type. Those voltages are significantly different. Resistors are a lot less $$ than special order sensors.
GregGillette
Jun 22, 2021 05:02 AM
Red FLHTK
Exhaust System Topics
Jun 13, 2014 07:36 AM
blackjeep
Oct 7, 2011 07:24 PM
smiley7661
May 14, 2011 06:53 AM
King_O_Road
Sep 21, 2008 11:43 PM
