Hey guys, Im getting a new tire on the rear so i took the wheel completely off (axle was a sombich to get out) along with the real caliper (not sure if it was necessary, but the manual told me to so i did) what im wondering, is when i go to reassemble, is there a way i can get the tension right without getting the belt deflection tool from hd? Also, do i need to replace the metal/rubber washers on the bolt that connects the brake line to the caliper or are those reuseable?
I have the proper tool which is easy to use. If you search the whole forum you will see recommendations to twist the belt just so as an alternative.
You didn't need to disconnect the caliper, if you have removed the hydraulic brake pipe from it. If you have you will have to bleed it with fresh clean fluid and I personally always fit new washers when reconnecting pipes. I only just did that a few days ago to my own rear caliper on my Glide.
I just use the twist to 45 deg. method for tension. Many a mechanic feels the belt tension Harley recommends is too tight. Some local dealers actually spec. their new bike with the belt not as tight as Harley recommends. Just twist the belt to 45 deg. and your tension will be good, not too loose or tight. Easy to do and no need for the tool.
I've used the tensioning tool and I've done it the "twist it the 45 degrees method." The twist it 45 degrees method is perfectly fine. More twist than 45 degrees is too loose, and less twist than 45 degrees is too tight.
