Build started
Old Mar 21, 2010 | 06:57 PM
Just Dave's Avatar
Just Dave
Wow you made good progress for the day, you’ll be rolling before you know it if work don’t get in the way to much.
Just Dave's Avatar
Just Dave
Old Mar 21, 2010 | 07:10 PM
redrubicon2004's Avatar
redrubicon2004
Originally Posted by masterblaster
got advice from another forum to use popsickle sticks, worked great.
I'd like to know more about that.
Old Mar 21, 2010 | 08:18 PM
Bertk's Avatar
Bertk
Found the channel...
Old Mar 23, 2010 | 07:50 PM
CroK's Avatar
CroK
Just a guess, but I'd say they worked the rings in from the bottom. The bottom edge of the cylinder has a small bevel. (Make sure you have the gaps set correctly, both directionally spaced and have already ground the ends of the rings so the gap width is correct). If you take a popsickle stick and work the ring in slowly and very carefully, you can compress each one as you come to it, while you move the piston up into the cylinder. Push the middle of the ring in first, and work your way around to each end. (Use the popsickle stick to do the pushing, so as not to scar the rings). Of course, this is just a guess...
Old Mar 23, 2010 | 08:17 PM
masterblaster's Avatar
masterblaster
Exacto! Thanks for putting words im my mouth CroK. Almost done, Installing a TMAT on a Dyna is a PIA. Will post up pics and write up this weekend.
Old Mar 27, 2010 | 09:25 PM
masterblaster
Okay, just took the Dyna for teh 50 mile break in ride, rode to Coral Gables in the center of Miami (perfect night for riding tonight)had 2 beers, looked at some horries and rode home. The Tmax is still dialing in so getting a little decel pop and a few back fires. The motor runs quiet, almowt too quiet, much less push rod and valve train noise than stock. Hope I tq'd everything right. The power seems fine bit not near my HQ 107 package, will have to do cams and heads now, I want this bike to scream. Putting a Tmax in a Dyna is a PIA.
mac1911
Apr 28, 2011 02:22 PM
fiscomi
Jan 6, 2011 02:31 PM
cccbebad
May 22, 2008 11:42 PM
so165
May 18, 2007 01:56 AM
Beefcake
Jun 15, 2005 11:02 AM
