oil change
Old Mar 28, 2010 | 08:08 AM
ziggy's Avatar
ziggy
Default oil change
I have a dyna fxdx and no oil tank, if i run the motor for 30 sec. after i drain the oil ,will that empty the old oil in the pump and oil filter?????
Old Mar 28, 2010 | 08:14 AM
jp13's Avatar
jp13
You will never get all the oil out unless you have the scavenger oil kit. I would not recommend running for 30 seconds.Let it drip as long as possible and put in the right amount, 2.5 qts I believe.
Old Mar 28, 2010 | 08:21 AM
ziggy's Avatar
ziggy
Default oil change
I was going to change over to syn today and wanted to get as much oil out as possible.I guess there is not alot of oil left in the motor to worry about.... Thanks
Old Mar 28, 2010 | 08:35 AM
wescoot2's Avatar
wescoot2
The small amount of Dino mixing with sythetic won't hurt anything. Just let it drain and add the $$$ stuff.
Old Mar 28, 2010 | 10:09 AM
mikeault's Avatar
mikeault
I wouldn't run it without oil. Bad, bad idea. If you're that worried about mixing them, I'd put in the 2.5 qts, run it for a bit, then change again. But synthetic isn't cheap.
Old Mar 28, 2010 | 11:19 AM
Taddeoeg's Avatar
Taddeoeg
+1 Remember they sell lots of blends as well - nothing wrong with mixing dino and synthetic.
Old Mar 28, 2010 | 11:41 AM
rdown1976's Avatar
rdown1976
I seized a cylinder before in ,my jetski....I would never want that to happen again!
Bluraven
Sep 12, 2021 04:18 PM
sturgis23
Harley Davidson Videos
17
Nov 2, 2016 01:46 PM
cajun1957a
Sep 10, 2016 08:35 AM
Knights2TheEnd
Sep 14, 2012 08:30 PM
