I used a larger flathead screwdriver that I wrapped in a shop rag to help minimize gouging the brake pad with the flathead tip. Just be careful and you should be fine.
ok i got it on now.. what about the belt tension? i have the axel as far back as it can go, the allens on both sides are tight. Is this right? also is there a torque value on the axel?
I didn't follow the manual as far as the loosening belt tension adjustment screws on the rear of the swing arm when taking the wheel off. So when I put mine back together the alignment and tension are right where they need to be. Did you adjust the screws on the back of the swing arm when you took it apart? If not you should be able to get away with the tension/alignment when you put it back together.
Can't advise on the torque spec since I don't have access to the manual right now. Good 'N' Tight will work for you for now
The manual explains belt tension, rear wheel alignment using a simple tool, and that the torque spec is 65 ft. lb.
Anytime you take off a wheel, put a paint stir-stick between the brake pads. This was an invaluable tip I got last year on this forum from someone.
The belt should be able to be turned no more/no less than 45 degrees.
Also, buy a service manual and parts catalog for your bike. You will need them and these books will allow you to do the job correctly without panicking.
