Fuel tank lift???
Old Aug 7, 2006 | 06:20 PM
hogwyld79's Avatar
hogwyld79
Default RE: Fuel tank lift???
Well I tinkered around with the tank a bit today and I think it will work. It seems like the 2" lift may put the front tank mounts in the way of the triple tree, but a 3" may be a perfect fit. I may have to shave down or bend the brackets that RudeDog sends. If all else fails I may have to move the tank back slightly. If Rudedog and I get things straightened out on our end then I will post any issues I have with the tank lift and the pics when I get it installed.
RudeDog, if I do have to modify your brackets I will take pics of them so that you can modify them before you send them out, if you want too.
Old Aug 7, 2006 | 11:27 PM
RudeDog's Avatar
RudeDog
hogwyld79 Date 8/7/2006 3:20:48 PM
That sounds like a great idea. I'll get them to you as soon as possible. Thanks for helping out alot of people, including myself.
Old Oct 31, 2006 | 07:47 PM
hogwyld79's Avatar
hogwyld79
Ok, I know it's been a while since I started this thread, but I am here to finish it. I purchased the fuel tank lift kit from RudeDog and finally had a chance to install it. For starters the lift will fit on without any mods, if you are willing to sacrafice approximately an 1/8th of an inch turning radius on either side. The lights and bars clear the tank with the lift on. I had to pull and stretch the wires from the frame to make the wires reach the speedo. Other than that it pretty much went on like it was meant to be there. I have more pictures that I will attach as soon as I get them from work. I am going to notch out my brackets so that the triple tree will clear the brackets. I will post and send rude dog the measurements of the brackets once I get them. RudeDog, thanks for the help bro. If you can fabricate the piece I need for a suicide clutch let me know, I hate to spend $300 from LaBriola when I know it's something that can be made for about $25.
Old Oct 31, 2006 | 07:50 PM
hogwyld79's Avatar
hogwyld79
CLose up pic
Old Oct 31, 2006 | 07:58 PM
phreak's Avatar
phreak
That looks great!
Old Oct 31, 2006 | 08:27 PM
WgSkee's Avatar
WgSkee
Looks great...... Good Job...
Old Oct 31, 2006 | 08:31 PM
hogwyld79's Avatar
hogwyld79
Thanks for positive reinforcement, once I get my new tins in I will have the brackets powdercoated the same color as the tins. Right now they are kind of a temp thing just to show people that they will fit the WG's.
Old Oct 31, 2006 | 09:04 PM
WgSkee's Avatar
WgSkee
Great mod for little $$.. Wish they could all be that way....LOL
Now that would be a challange..... Later Skee
Old Nov 2, 2006 | 08:58 AM
RudeDog's Avatar
RudeDog
Hogwyld I shot you a PM. I knnd of have an idea what you did to make it work but I would like you to verify that I am seeing this right.
The Wide Glide looks great with the tank lift on it! It looks better than I thought it would. Maybe because it's on an Evo instead of a TC 88.
Old Jan 12, 2007 | 06:48 AM
willmeg's Avatar
willmeg
6th Gear
Default Tank Lift for 94 fxdwg
Rudedog. I too live in the UK and after reading this thread would be interested in a 3inch tank lift for a wide glide. If you still are making them how could I pay you and could you send it to a freind of mine in Texas.
If not possible could I have a design or something to try and have one made in the UK.
Many Thanks
Russ
