A question about rake and trail about a specific bike
Old Apr 6, 2010 | 10:22 PM
JustDave71's Avatar
JustDave71
Default A question about rake and trail / raked trees / 95 FXR
Came across this bike on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...m=260578623139
That is one SICK bike. Not in love with the paint, but overall it's clean as **** and seems to have just the right amount of work done to it while keeping the stock look
One thing, though...
5 degree trees. I believe factory rake on that bike would be 32 degrees, no? Consensus seems to be that raked trees on anything short of what...36 degrees or even a couple more is a bad idea.
I asked the seller about this and he says it handles beautifully, and made a point about lowering increasing rake (obviously if you lower the back you increase rake and trail somewhat) but that didn't seem quite right to me?
Anyway...he emphatically states that it handles quite well.
Curious what the knowledgeable here think? I'm sure there are some bored dudes looking to share their opinions!
OH, and if the seller sees this...Im not criticizing, just asking. Besides...free publicity!
Old Apr 7, 2010 | 06:22 AM
pococj's Avatar
pococj
If the bike has been lowered in the tail, the rake will increase. That will allow raked trees to be added that are slightly greater than the usual 3 degree trees without getting into trouble with too little trail. Whether that is the case with this particular bike can only be determined by measurements.
Old Apr 7, 2010 | 07:26 AM
JustDave71's Avatar
JustDave71
seller states bike is lowered both front and rear.
understood on measurements.
that sure is a sweet scoot!
Old Apr 7, 2010 | 07:41 AM
toastman's Avatar
toastman
wow. REALLY clean.
lots of attention to detail on that bike.
no input on the rake/trail issue, just wanted to say nice bike.
Old Apr 7, 2010 | 07:44 AM
JustDave71's Avatar
JustDave71
Originally Posted by toastman
wow. REALLY clean.
SUPER clean, innit!
As clean as it is...$12k probably isn't gonna happen. He indicated he might go down to $10k, but even that seems a bit steep.
If I had the money to bargain with I'd probably be looking into that sucker.
Old Apr 7, 2010 | 08:57 AM
rounder's Avatar
rounder
FWIW I am running wideglide trees on my FXDC. The trees have rake in them(I believe 2 deg). Stock the trees have no rake. Anyways, the bike is stable and handles great with the small amount of additional rake. I think that it will be just fine on that bike having an additional couple of deg. of rake. With the bike lowered, it has a very reduced lean angle and as such you probably won't be able to notice any ill effects cornering cause you really can't get the bike over that much anyways. Also at low speeds the additional rake supposedly will cause the bars to want to fall more into the turn. Again this will not be all that noticable if you didn't have anything to compare it to as you will just ride the bike and adjust to its characteristics.
Old Apr 7, 2010 | 09:02 AM
JustDave71's Avatar
JustDave71
5 degrees is a lot more than "a couple"
Hell...I'm not buying the bike anyway, but if I was I'd get an inspection first and have the inspector get the measurements necessary to get a general idea what the trail is.
Point is, general consensus is that 5 degrees on a stock bike is a flat-out no-no, but the seller says the bike handles perfectly fine at all speeds.
damn I love that bike.
I should take up a collection. Y'all wanna sponsor me?
Old Apr 7, 2010 | 09:07 AM
toastman's Avatar
toastman
hahah i think if you were actually interested, had the money in front of the seller, and had your reservations about the handling, a test ride would either confirm or put to rest your unease.
so asking questions is alright, but if it were me i'd wana test ride to be sure.
Old Apr 7, 2010 | 09:19 AM
JustDave71's Avatar
JustDave71
yeah...I see a LOT of ads that say "NO TEST RIDES!"
But...the wobbles that improper trail can cause aren't something that'd necessarily come up under test ride conditions, ya know?
It was just interesting to me that this setup defies common perception, at least according to the seller as far as handling goes.
so, toast...you gonna pitch in so I can score that scoot?
Old Apr 7, 2010 | 09:25 AM
toastman's Avatar
toastman
yeah, sure.
just so we're clear, any monetary contribution i make is to be considered a deposit. instead of a loan, think of it as child support.
we can draw up a contract but in simple terms...X amount of dollars means X amount of rides yearly.
kinda like having joint custody of a kid.
sounds good?
