Detachable sissy bar mounts squeaking.
Old Apr 10, 2010 | 06:55 PM
rockymtnhigh's Avatar
rockymtnhigh
Default Detachable sissy bar mounts squeaking.
Since installing my detachable sissy bar a few days ago I'm hearing a high pitched squeak (like a cricket chirp) when the engine hits a certain rpm. I only use the sissy bar when I carry passengers so I'm wondering how to fix this noise. The kit came with metal washers... perhaps some rubber ones would be better? Suggestions?
Old Apr 10, 2010 | 07:39 PM
HDDyna2006's Avatar
HDDyna2006
I rolled some silicone plummer tape on mounting post, or black electrical tape,
finally slide small O ring into clamp, also place O ring on front mounting post
Old Apr 10, 2010 | 07:40 PM
Taddeoeg's Avatar
Taddeoeg
First, remove the sissy bar and see if the noise continues at that rpm. If so, lube everything that could move.
If not, look elsewhere.
Old Apr 10, 2010 | 11:10 PM
rockymtnhigh
Thanks for the advice. **** just started squeaking after the install so I know it's got to be the mounts.
Old Apr 11, 2010 | 12:51 AM
berk483's Avatar
berk483
3rd Gear
I had the same noise when I put on HD saddlebags...It turned out being the Strut Cover was vibrating at a certain RPM like you said. Try tightening down the bolts for the struts and see if that helps...It only took another half turn on my bolts to get it to stop.
speedy540
Apr 10, 2013 05:06 PM
2XNightTrain
Aug 11, 2011 07:26 PM
MONSTRIP
General Topics/Tech Tips
Jul 29, 2008 01:08 PM
SIM
Aug 7, 2007 02:45 PM
ckgdrums
Feb 15, 2007 04:29 PM
