Dyna front end chatter
Old Apr 12, 2010 | 01:46 AM
Zinje's Avatar
Zinje
Default Dyna front end chatter
When i am at a dead stop and the engine is idle, my front end chatters (metal to metal) when i lock my steering right or left. Does your dyna do this?
Old Apr 12, 2010 | 02:03 AM
transam7969's Avatar
transam7969
...no
Old Apr 12, 2010 | 05:15 AM
maddghost's Avatar
maddghost
Mine either, but why would you do that? If you must do it try revving just a little and see if it goes away ,second place to check is prolly your tank bolts.
Man i bookmarked your vid for yhose rainy days when I'm stuck in da house!!! Cool vid!
Old Apr 12, 2010 | 07:34 AM
shimmon's Avatar
shimmon
Could be a number of things. Tank bolts is a good and easy check, these tend to loosen if not loctited. also could be a loose clutch lever, man rattles real good if its not tightened to spec, and having the steering locked in a direction would generate more fibes from the engine to the handlebars. try locking it in a direction and grabbing your levers, mirrors, turn signals, and anything else you can try to find the rattle.
Old Apr 12, 2010 | 07:47 AM
toastman's Avatar
toastman
yeah i agree with the above.
check your tank bolts first.
if that's not it touch everything you can get your hands on on the front end of your bike to locate the vibration.
check the bolts on your brake calipers, too. i had loose bolts there on my fatboy and it vibrated like a ****.
Old Apr 12, 2010 | 08:45 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Take an hour and tighten everything you can see. I do that once a month in season. Something always loosens up. My clutch lever buzzes like crazy.
Old Apr 12, 2010 | 10:09 AM
Zinje's Avatar
Zinje
Ya thanks for the input guys. This shizit is driving me nuts. Let you know what i find out.
Old Apr 12, 2010 | 10:48 AM
DanD's Avatar
DanD
I had a weird sound like that once on mine...turned out it was the bike bell.So don't overlook anything.
Old Apr 12, 2010 | 11:37 AM
blackmopar's Avatar
blackmopar
+1 on clutch lever - but i assume youve tried holding it to see if the noise goes away
customglide57
May 7, 2014 06:40 AM
hd_rolling
Feb 6, 2014 04:13 PM
Nagoc
Jun 4, 2013 09:49 PM
por2gezo
May 24, 2012 05:21 PM
RED_5
Sep 24, 2010 11:55 AM
