not even the summer yet and i'm already looking forward to my mods for next winter.
with my cosmetics 99% done i'll either be upgrading my suspension, my motor, or finishing the looks of the bike with a 21/18 setup and a smooth full lenght rear fender.
how much dinero would i be going in for by doing a good set of cams in my stock motor? something along the lines of the andrews 54h...
not really looking for this cam is better, don't waste your money on just cams, etc.
we're in the spitballing stages of everything right now, it's riding time, i'm just looking ahead...
i just did the andrews 54h cams in my 08 street bob i found the cams and adjustable pushrods (wich you dont need ) for 225. you can get the cams new on ebay for about 238 ...my bike runs great it pulls very hard and runs much cooler ....and my thunderheader really came to life..i did the install myself just basically followed advice from the forum members ie lama. also i didnt need new springs they bolted right in...
I got my woods cams used on ebay 200, rocker box gaskets 25, oil and filter 45
tools is a big factor, borrow or rent. Cams only tuned 94 hp 101 tq for about $300.(250 for a tune)
Spence
I think stock springs will go to .585 lift. By getting adjustable pushrods you can cut out tank removal and lots of labor. Be sure to inspect oil pump and measure crank pinion run out while you are in there........
Are you doing the work yourself or paying a shop to do it?
Year of the bike for cam tensioners?
You will want to upgrade to the Timken bearing.
Do you have fuel management or is that something you are going to have to buy?
Dyno tune or go the TTS route and tune it yourself?
What he said.
I just had a local indy install andrews on my 09.
I did get the adjustable pushrods and went with the PCV fuel management and Dyno'd. whole thing with labor was about $1200
i do a lot of tinkering on my bike, but haven't dug into the motor at all yet. that being said i'd like to do the cam install myself. my dad's been riding and fixing harleys for 40 years so i'm not totally flying by the seat of my pants.
it's a 2008 street bob.
i'm running the PCV and if i decide to go with cams i'll more than likely pick up the autotune module that i shouldn't have skimped on in the beginning. either that or i'll get the bike back on the dyno.
The Andrews info I have says you need HI-LIFT springs for the 54H with .550" lift. The 50H has .510" lift and can use stock spings.
Your'e going to loose a lot of dynamic compression with that much change in duration unless you raise your static compression ratio. That will kill your off the line power. I've been thinking about the 26H which is the biggest recomended for stock compression although if the Harley engine reacts anything like a V8 the 31H would probably work.
Just my.02. I like the torqe off the line and with out a lot of other changes to the compression ratio and gearing a big cam which is also a high rpm cam can be a big disappiontment.
