Tall risers/drag bars or T-bars?
Old Apr 26, 2010 | 07:12 AM
budman1950's Avatar
budman1950
Yeah, me too. Kinda frustrating...
Old Apr 26, 2010 | 10:22 AM
frosgotboost's Avatar
frosgotboost
6th Gear
Default attached images
Just figured it out this am. Once you make 5 post you can see them.
Old Apr 27, 2010 | 05:16 PM
DynaStorm's Avatar
DynaStorm
Originally Posted by jaysonL
How about a few more pics , at different angles ?
k jayson - as per request, a few more shots..enjoy!
hope these satisfy your cravings.
Attached Thumbnails Tall risers/drag bars or T-bars?-dsc_0001_0015.jpg   Tall risers/drag bars or T-bars?-dsc_0003_0017.jpg   Tall risers/drag bars or T-bars?-dsc_0008_0021.jpg   Tall risers/drag bars or T-bars?-dsc_0010_0023.jpg   Tall risers/drag bars or T-bars?-dsc_0014_0026.jpg
Old Apr 27, 2010 | 09:25 PM
martinbrody's Avatar
martinbrody
Whats the difference between a t bar and a drag bar, Wild 1 has a 10" drag and a 10" T?
DynaStorm are you using the stock cables? Those bars look great. I have an 09 FXDC and would like the bars higher so I am not leaning forward as much, I was thinking risers with the buckhorns but after seeing your scoot I think I found what I am looking for. Did you put them on yourself, if so how did it go? Not interested in paying a grand to have them installed.
Old Apr 27, 2010 | 09:45 PM
DynaStorm's Avatar
DynaStorm
Thanx for the comments!..I love 'em...Am using stock cables/brake/clutch, I thought I would need brake cable, but simply re-positioned the fitting, so it points downward. I find these much more comfortable, not hunched over. and Yep, did the install mahself...was straightforward...one thing I would change, is to lift the tank, to access wiring, and pull the pins to avoid cutting and resplicing harness...the only small aside, was avoiding a pinched power lead for run/kill switch. Wild1 has a few useful tech tips on their site to help out with this.
Old Apr 28, 2010 | 01:42 PM
hacksawsgarage's Avatar
hacksawsgarage
normally a drag bar is a bar with no rise and some pull back. a broomstick has no pull back. these bars need risers.
a Tbar obviously doent use a separate riser.
but i am sure the wild1 site shows non tbars as i described, as drag bars.
the problem may also be related to bars made for springer front ends because they have diff mounting spacing. wild 1 maybe trying to differentiate between 2 otherwise similar in appearance bars.
Old Apr 28, 2010 | 04:47 PM
jaysonL's Avatar
jaysonL
Those really look nice ! I bet they're comfortable . Thanks for the pics .
Old Apr 28, 2010 | 04:51 PM
jaysonL's Avatar
jaysonL
Originally Posted by N-gin
Not quite finished. this has actually sockets simulating the extension for the risers but you get the idea.
I like it !
Old Apr 29, 2010 | 05:42 PM
ecvjohnny's Avatar
ecvjohnny
t-bars have a straight riser, the drags have a curved riser.
Old May 6, 2010 | 10:03 PM
danl's Avatar
danl
Cool forgot
Originally Posted by fhansen
I like this set-up. Would you mind posting some more pics on it?
Sorry fhansen, here are some pics
Attached Thumbnails Tall risers/drag bars or T-bars?-riser1.jpg   Tall risers/drag bars or T-bars?-bars.jpg   Tall risers/drag bars or T-bars?-riser2.jpg
