Baker ipb seal leak
Old Apr 17, 2010 | 07:17 PM
Greazzie's Avatar
Greazzie
6th Gear
Default Baker ipb seal leak
On my second ipb seal from the baker ipb kit (06 street bob). Anybody else experience this? 1st one was a blunder on my part, but the second one was by the book. Still leaks, but
only after riding. Defn not trans oil, running shock proof heavy there, and I can see it
coming from the IP side.
Old Apr 17, 2010 | 07:28 PM
thedonthere's Avatar
thedonthere
No issues with mine. No runs,drips or errors!
Old Apr 17, 2010 | 07:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Next time you have it apart, check the surface of the shaft where the seal rides, could be the problem is not the seal.
Old Apr 17, 2010 | 08:50 PM
cactusred's Avatar
cactusred
Not me man, all appears good to go on mine
Old Apr 19, 2010 | 03:06 PM
Greazzie's Avatar
Greazzie
6th Gear
The first time around I realized that I had put the seal in backwards. Given how the
seal is designed I didn't think it would be a problem, but when it started leaking I figured I
had better replace it (CYA). Made sure the 1st and 2nd time that the main shaft was alright, took some 600 grit to it, checked for nicks, etc... Went on a ride on Sat. leaked a few visible drop after the 1st 100 miles or so, after that seem to get a bit better. Can't visually see it drip anymore, but can still feel the oil on the backside of the IP case.
Sam01
Oct 2, 2018 09:28 AM
2wheeltravelin
Jun 22, 2013 02:30 AM
cdrich
EVO
May 22, 2012 05:01 PM
jkford45
Mar 20, 2010 11:02 AM
The Old Man
Apr 22, 2009 06:27 PM
