Carb question?
Old Apr 21, 2010 | 12:13 PM
lennyb3us's Avatar
lennyb3us
Default Carb question?
I have a 2000 dyna lowrider and i am looking to change the slow and fast jets on the carb and shim the needle. What type of carburator comes stock on this bike? It has a hrley stamp on it. Also how the heck do i get the air filter off of there. Any help would be greatly appreciated
Old Apr 21, 2010 | 03:41 PM
bigdaddy33's Avatar
bigdaddy33
I believe it's a Keihin CV carb. That's about all I remember since I switched over to an S&S Super G years ago.
Old Apr 21, 2010 | 05:43 PM
lennyb3us's Avatar
lennyb3us
Thanks. nice ride by the way. do the s&s do alot for performance??
Old Apr 21, 2010 | 06:58 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The stock is a Kiehin CV carb. The air cleaner cover is held on with a big philips screw. The set up I am running with is, believe it or not, the stock jets. A #45 pilot and a #195 main, I shimmed the needle with 2 #4 brass washers and turned the air/fuel mix screw out 2 1/2 turns from lightly seated. There is a plug that covers the a/f mix screw, that has to be removed. What mods have you done to mod the carb?
Old Apr 21, 2010 | 09:43 PM
bigdaddy33's Avatar
bigdaddy33
Yes. Needed a bigger carb when we increased the displacement of the motor, now 117", compared to the stock 88".
Old Apr 21, 2010 | 10:17 PM
BLKBAGGER's Avatar
BLKBAGGER
Not trying to flame you but if you can't figure out how to get the air filter off you might think about having someone re-jet your carb for you. It takes a little experience to get a bike jetted correctly if you have never done it before. You might get away with just a needle change and/or mixture adjustment.
Old Apr 21, 2010 | 10:23 PM
1931jamesw's Avatar
1931jamesw
Or, you could always go with a mikuni hsr 42mm carb. It's my favorite carb!
Old Apr 22, 2010 | 01:12 AM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
Which requires even more specialized knowledge to tune properly.
Old Apr 22, 2010 | 08:51 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 If you are going to get a bettter set up...go Mikuni
Old Apr 22, 2010 | 08:52 AM
KBFXDLI's Avatar
KBFXDLI
Hey, cut the brother some slack and quit trying to be his MOTHER. he wants to work on his bike himself and needs some advice. Go back and f**K with the bagger guys....
