foot problem
Old Aug 11, 2006 | 07:09 AM
dav.elis's Avatar
dav.elis
Default foot problem
I have a problem with mr right foot... my shoes melt on the slip-on!!!
What about shoes and what about accessory for not touch the slip-on?
Old Aug 11, 2006 | 10:07 AM
nine11c2's Avatar
nine11c2
Default RE: foot problem
I wear Herman's Survivors. Have had a pair for 10 years and still going strong. You could ride with your foot on the pipe and not feel it. It's the 400 gram Thinsulate boot. Herman's is no longer around, I believe the name they put on the boot is Smith's. This is one of the boots:
http://www.workbootwarehouse.com/cat...?ProductID=206
They are tall, waterproof and last forever. On the rare occaision I get caught in the rain, I'm dry on top of my head and from where the boots start down. Everything else is wet...
Old Aug 11, 2006 | 10:18 AM
Psycho's Avatar
Psycho
I wear the danner wildland firefighter boots. They do double for me. Work boots and ride boots. You don't neccessarily have to have the danners though, any boot with a vibram sole will suffice.
I do reccomend the danner wildland fire boots though. Comfortable, excellent quality boot, made in USA.
Old Aug 11, 2006 | 10:52 AM
Bassman's Avatar
Bassman
I was having the same problem. I started to really pay attention to my foot placement making sure my heel was not on the pipes and after awhile I noticed I naturally am keeping it off the pipes now
Old Aug 11, 2006 | 11:00 AM
thebestofindica's Avatar
thebestofindica
See if your shoes are covered under your warranty
Old Aug 11, 2006 | 11:29 AM
dav.elis's Avatar
dav.elis
It's not a problem for shoes but for my slip-on that I must polish every evening for an our....
All vibram sole are thermo resistant?
Old Aug 11, 2006 | 12:19 PM
SUPER01's Avatar
SUPER01
Your just going to have change your foot position. Once in a while I rest mine against it but it only leaves a small mark so it's not too bad to polish off. Dickies black steel toed work boots.
Old Aug 11, 2006 | 01:36 PM
Psycho's Avatar
Psycho
Yes, as far as I know.
http://www.boot.com/bsoles.htm
Old Aug 11, 2006 | 01:40 PM
Psycho's Avatar
Psycho
They're all fire resistant, but you'd be better to look for a set of boots with the #100F vibram soles. These are the ones used in the fireline boots, and offer increase fire resistance, plus oil resistance. We're required to have them on the fireline.
Old Aug 11, 2006 | 02:17 PM
kaduku's Avatar
kaduku
Either get boots that don't melt, or do like what I do, after riding I check the mufflers, and if there is any scuffs, I simply wipe them off while they are fresh and hot, comes right off. Only problem is when you forget! Then I use one of those deodorant looking sticks for muffler scuffs.
