Cupola Dumb Questions From FNG
Is this fairly normal? I don't remember these sounds from my 84' FLHTC. But, then again, I don't remember a lot of things. It's been 20 years since my last ride, so maybe I'm seeing (and hearing) ghosts.
2. Also, the gas guage doesn't seem to be accurate. At all. I put 100M on it since my last fill up and the guage is trying to tell me it's empty. Would you guys and/or gals bother the dealer with that or is it pretty normal for these gas guages to not be accurate? I'm sure it's a simple float and if the tank is two pieces (it has to be, I think) I could see where the guage would be a total WAG (wild-assed-guess) most of the time.
I'm sure you all get tired of holding newbies' hands but if you're really bored.............
As for the gas gauge, ignore it. They never work very well. If you want to try and fix it, you an pull the float out and tweak it a bit/adjusting until it reads close to accurate but with only a 5 gallon tank there really isn't much accuracy anyway. Your best bet is to go by your trip meter. Reset it when you fill up. Ride until you get worried, refill and note how much you put in. Adjust your fuel stops according to how much is left in the tank. Or strap a 1 gallon tank to your bike and ride until empty. Then you'll know how far you can go.
As to the sounds, it could be you are just very aware of sounds since it is a new bike, but, if you are lugging the motor, it will sound different. Do you get the same noise if you bring the RPMs up?
G: None taken. I appreciate you taking the time to address dumb questions from a new guy. If I down shift, the noise goes away. If I apply throttle it goes away once I reach a certain speed. My bad. I'm getting used to riding the new machine. It's quite different from my old 77 SG (4-speed) and my old 5-speed FLHTC.
G: On the older bikes, they had a 'reserve' so that if you had to switch the reserve on, you needed to start looking for fuel. Is the low fuel warning light on the new FI models somewhat accurate or are we taking a chance on having to push a VERY heavy motorsickle down the road?
With the sound going away if you downshift, I'm more inclined to believe it's the compensator. Basically what you have is that while the motor is lugging, it is surging between applying power through the primary and the primary going slack which causes the compensator to ramp up and down creating a clacking sound.
As for the reserve on carbed bikes, yeah we don't have that on FI unfortunately. The fuel low light on these bikes is actually a best guess from the ECM based on past tanks and riding style so it is fairly accurate. On my bike, which I pretty much just commute on nowadays (silly youngins), my light comes on at about 160 miles on the tank. I know for a fact that I can go 194 miles to empty with the way I ride, so that's basically close to the old carb style reserve. If you want to look at it that way.
Your best bet is to calculate your MPG the way you ride and then calculate your range from there. You'll be within 10 miles with this method.
Regarding the gas gauge - I am fortunate because on both of my bikes, the gauges are usually so full of moisture I can't see them. My wifes bike has no gauge. Like everyone else has said, rely on the odometer.
Especially a new motor but really any motor.....
Keep the rev's up and try to never bog her down like that. At times we all I think (in different senerios) wind up lugging here or there until we shift out but you really want to get it through your mind now that lugging is not good for this motor.
PS- It's not a dumb question....enjoy.
Once I get it broke-in to the point I feel comfortable, I'm putting some V&H Twin Slash slip-ons on it, along with a tuner and a Hi-Flow A/C. That should help. It's just too darned quiet. In my Owners manual, on page 28, it states flatly, "Your motorcycle has Catalytic Converters."
Where they are, it doesn't say. I assume they're in the muffler body. I would think they'd have to be.
Thanks a pantload, EPA. Bunch of freaking weirdos.
