Front Light
Old Apr 30, 2010 | 08:29 AM
mysiar's Avatar
mysiar
Default Front Light
Hi
Fresh owner of Dyna Wide Glide 2010.
Looking for help to fix my front light as the original one is hopeless.
Does anybody know what is the biggest in Watt manner bulb I can put into the lamp ?
Any tips more than welcome
Regards
Piotr
Old May 4, 2010 | 04:32 PM
Wonkaboy's Avatar
Wonkaboy
Welcome to the Dyna Forum , I don't have an answer for you but i'm sure you will get some responses soon !
" Looking for help to fix my front light as the original one is hopeless."
Old May 4, 2010 | 04:44 PM
trip20's Avatar
trip20
I'm running a Sylvania Silverstar Ultra in mine..... bright as hell and my wiring isn't fryin' so I guess it's ok.
Old May 5, 2010 | 06:39 AM
mysiar's Avatar
mysiar
I have similar type from Philips but I wondered if it would be possible to use 100/90 W safely for electric system on the bike
Old May 5, 2010 | 06:56 AM
08fxdf43202's Avatar
08fxdf43202
Originally Posted by mysiar
Hi
Regards
Piotr
This one works pretty good for me:
Old May 5, 2010 | 09:39 AM
grbrown's Avatar
grbrown
Wink
Hi
Regards
Piotr
This subject pops up over in the Touring forum as well. It might be worth calling in there and taking a look at recent threads. IMHO you should consider buying a new reflector first, then fitting a good quality bulb.
Old May 5, 2010 | 09:41 AM
grbrown's Avatar
grbrown
It is possible the stock wiring won't be man enough for that wattage. It would be a good idea to think of using a relay, so the bike wiring only does the switching and extra wires carry the power to the bulb.
Old May 5, 2010 | 10:48 AM
mysiar's Avatar
mysiar
thanks guys for all the tips,
I decided to leave the electric system as it is and install xenon kit to rise "power of light"
Old May 5, 2010 | 11:02 AM
AR-15 DEUCE's Avatar
AR-15 DEUCE
I'm running a 90/100..been doing it for 7 years no problem,I did remove the rubber boot,so the heat can dispures better,and my bulbs last oh two years,but I buy a pack of two from any local ricer shop for 20 bucks..I look like a damm train comin at ya
Old May 10, 2010 | 09:44 AM
mysiar's Avatar
mysiar
xenon kit is back to the shop - it is made for cars, no way to fit all this bit and pieces
I'm going to try 100/90 W bulb
