New Air Cleaner high flow options
Old May 2, 2010 | 03:51 PM
1320go's Avatar
1320go
Smile flters
If you like the looks of the stock set up you can always go with a K+N replacment filter and just open up the back half of your air box around the filter with a small hole saw. Cost of filter ,about $75.This said I later went with SE set up for looks.
Old May 2, 2010 | 04:45 PM
nevil's Avatar
nevil
Originally Posted by dmftoy1
Arlen Ness Big Sucker here - I went through the same decision process and decided that I like the way the Arlen Ness uses banjo bolts to eliminate the PCV hoses. (also a nice touch is to have a little shelf that routes oil from the PCV down into the throttle body intake)
The only knock I can say about the Arlen Ness kit is that it's not made in the USA.
Mine says "Made in USA"
Old May 2, 2010 | 04:57 PM
lionsm13's Avatar
lionsm13
Mine too on the Ness A/C, mine too.
Old May 2, 2010 | 05:02 PM
dmftoy1's Avatar
dmftoy1
Haven't checked the box on mine but here's what I was basing it not being made in the US on:
http://fuelmotousa.com/harley_filter.htm
Scroll down to the Arlen Ness Big Sucker.
Regards,
Dave
Old May 2, 2010 | 05:06 PM
nevil's Avatar
nevil
I will have to check my box later, I had the filter off today and it said Made in USA on the filter. I didn't look at the backing plate.
Old May 2, 2010 | 06:46 PM
Nick0915's Avatar
Nick0915
I just dropped a lot of coin on a S&S Tuned Induction setup. My buddy has this on his Rocker...it's pretty awesome..
Old May 2, 2010 | 10:00 PM
2009FXDF's Avatar
2009FXDF
RSD Mission Cut... Happy B-Day.
Old Feb 23, 2011 | 10:13 AM
antman27's Avatar
antman27
Originally Posted by paul s
I vented mine outside.
Hey Paul what set up is that ?
is it the Arlen Ness Big Sucker with a harley cover ? Looks hot ~
Old Feb 24, 2011 | 12:42 AM
HemiOrange's Avatar
HemiOrange
Ditto on the Ness. I used their stage 1 until I built the engine, then swapped in the 5/8" deeper Wimmer replacement air filter kit. It fits the SE and the Ness, while still using the stock style covers.
Old Feb 24, 2011 | 12:57 AM
editbrain's Avatar
editbrain
I am looking into the kuryakyn Hi-Five. I have been viewing my intake air temps from data logs with the SE A/C for the Dyna using the semi oval, and the air temps are extremely high.
I feel that the kuryakyn Hi-Five or RSD would provide a cooler air intake temp.
Anyone like to comment on this? Thanks.
drukanfu
Touring Parts
Aug 14, 2012 11:16 PM
AbnMP13
Touring Parts
Jun 4, 2012 04:00 PM
Scubadog
May 23, 2010 01:29 AM
FrankT
Feb 5, 2009 07:11 PM
papapuskit
Aug 24, 2008 05:57 AM
