Any SB owners rotate their stock apes more vertical?
Is it likely I can't tighten the riser clamps sufficiently without a torque wrench? Not really. But if I start taking short cuts on simple things, what's next? Hell, why break out the pressure gauge when filling the tires - just pump 'em up by sight. No need to keep track of how much oil you put in on the next change - long as it isn't empty or overflowing, you're good, right?
There are two contact patches smaller than a pack of cigarettes between you and the pavement. Plus whatever safety gear you choose to wear. I prefer to try to tilt the odds in my favor by ensuring that everything about my bike is right before I go out there and dodge the cagers hellbent on squashing me.
Your bike, your life, your choice. For me, I feel better knowing I heard that 'click' that says the riser clamp bolts are properly tightened and if some jerk cuts me off and I have to slam down on both brakes the inertia throwing me forward isn't likely to twist the bars and cause me to lose control.
But that's me. I don't expect others to agree.
So, I have a quick question: Are they supposed to tell you how much pressure you use to tighten something down? If so, how tight do you tighten?
I know...I'm still pretty ignorant in many mechanical issues. But, I'm learning.
to be honest if i weren't too lazy to dig out my service manual every time i tightened something down my torque wrench would see more use.
as it stands, i yanked on the riser clamp bolts until i thought i was gonna crap or pop a blood vessel. haven't moved on me so far.
why do everyone's 14" apes look taller than my 14" apes?
i'm headed outside with a tape measure...
Or, it could also be the photo angle?
Regardless, you have some of the best looking apes on this forum IMO...so be proud of 'em!
