another lowering thread
Old May 4, 2010 | 09:56 PM
toastman's Avatar
toastman
Default another lowering thread
wana drop the rear with some 11" progressives, but i have a few questions.
how much will an 11" shock lower the rear of my bike?
i want my pipes to stay level to the ground and not sag in relation to my swingarm, so how much would i have to lower the front with the drop in kit to keep the bike level?
thanks all.
Old May 4, 2010 | 10:51 PM
lhcstreetbob's Avatar
lhcstreetbob
i have the 11 inch 412 shocks and the drop in lowering kit with 1 inch spacers all progressive and my bike sits about level...
Old May 4, 2010 | 10:54 PM
toastman's Avatar
toastman
thanks LHC...your bike is sick as f*ck by the way.
i wana lower it but i don't wana end up with the rear of my pipes pointing at the ground. that's why i wana know what's gonna keep the front/rear relationship the same as stock only lower.
Old May 4, 2010 | 11:03 PM
MyBeerBelly's Avatar
MyBeerBelly
im pretty sure my rear shocks are 11inch 440s and i used the progressive drop in kit for the front with 1 inch spacers. It sits level
Old May 4, 2010 | 11:37 PM
lhcstreetbob
thanks man shes getting there ..if you do the drop in kit you can cut a different size spacers to see what ya need ...its a pretty easy kit
Old May 5, 2010 | 12:40 AM
toastman's Avatar
toastman
i've heard nothing but good things about the ease of the drop in kit.
i just want to make sure i know all the measurements so my bike ends up sitting level.
Old May 5, 2010 | 03:23 AM
PigInaBlanket's Avatar
PigInaBlanket
Mine is lowered in the back with 11 inch Progressive 412 shocks and the front is stock with no lowering.
Old May 5, 2010 | 06:15 AM
toastman's Avatar
toastman
and your bike looks great, but extend your pipes towards the rear of your bike.
see how they would dip below your swing arm pointing down towards the ground?
that's what i want to avoid.
i just wana know how much 11" shocks lower the rear so i know how much to lower the front to match.
so far it's looking like 1" but i wana be sure.
Old May 5, 2010 | 06:38 AM
rounder's Avatar
rounder
there will be a gap between the swingarm and the pipes which is unavoidable. With the bike lowered, the swingarm moves up toward the fender and points to the sky. You can make it so the frame is level and the pipes don't point down, but, the gap will occur unless you get an upturning exhaust, like a thunderheader.
Old May 5, 2010 | 07:13 AM
jshull's Avatar
jshull
I did progressive 11" 412 hd and the progressive full front lowering kit. I called progressive and the suggested the full front over the drop in, I also changed to SE heavy fork oil, made a huge differnce. but with the big shots on my bike the swing arm points to the sky.
