Question: Down Shifting for Torque
Old May 12, 2010 | 01:37 AM
editbrain's Avatar
editbrain
Default Question: Down Shifting for Torque
What is your proper way to down shift to get the RPMs up when passing or playing?
Do you just clutch, down shift and pop the clutch?
Do you clutch, rev motor, then pop the clutch?
Could you explain your methods? I am just curious. I don't have a method, and would like to know what you think the proper method is that is not damaging to the motor and other components.
Thanks.
Old May 12, 2010 | 01:57 AM
kk6pg's Avatar
kk6pg
Pull in the clutch, crack the throttle and downshift at the same time, ease clutch out. The radical deceleration jolt if you dont match RPMs is the fastest way I know of to twist a crank.
Old May 12, 2010 | 02:34 AM
thedonthere's Avatar
thedonthere
put a 30 tooth transmission pulley and twist the throttle
Old May 12, 2010 | 03:12 AM
thedonthere
pardon me
Old May 12, 2010 | 04:16 AM
==ShaDoW=='s Avatar
==ShaDoW==
till the clutch is engaged (released) you are just revving engine so my advice is smooth change then twist throttle (if your in correct gear passing should be no issue.
Old May 12, 2010 | 05:33 AM
spaceblue's Avatar
spaceblue
The real truth here is for any given speed the engine has to turn faster in each successively lower gear. In other words at 40 MPH the engine will turn X in 4th gear and xx in 3d gear. By cracking the throttle as you down shift from 4th to 3d you are bringing the engine RPMs up to the level they would need to maintain the same speed you are now doing in 4th. This process takes practice to get right and can apply to any standard shift transmission on any vehicle.
Old May 12, 2010 | 07:00 AM
8541hog's Avatar
8541hog
Good explanation, and yes it takes a little practice to time it all right and give it the right amount of throttle. And yes, ease the clutch out when downsifting, not like a granny, but don't let it slam either.
Old May 12, 2010 | 07:06 AM
SC-Longhair's Avatar
SC-Longhair
Really? You're asking how to pass on a motorcycle? My suggestion: MSF course and learn how to ride.
Old May 12, 2010 | 07:19 AM
8541hog's Avatar
8541hog
Be nice Vic... I don't think the course really talks about downshifting much and technique. Hell, Ewa says they didn't even tell her about the big paint strips and how slick they get in the rain.
Old May 12, 2010 | 07:21 AM
SC-Longhair
Ooooooh, awright.
That may have been in the beginner course. What about intermediate and advanced?
