Ok was reading an article on spark gap. For every 12.5 Hp added to our engines, it mentions to reduce the plug gap by .004. So add cams and a stage 1 and maybe the gap should be around .032-.036 or so....anyone else actually do this. The reduction in gap is not done if a high performance ignition system is added.
I don't know why someone would do this. Unless they're concerned about the extra air flow quenching the spark.
I know, if you put a supercharger on something, you have to be careful with spark gap because the big increase in airflow can literally blow out a spark.
But on a naturally aspirated engine? There's a lot of things I haven't heard of, and this could be one of them.
Yeah, I don't know. I have just done cams and retuned the carb on my bike. FWIW the plugs are showing too rich for how my carb is setup. I have run the bike set this way before the cams and the plugs were not reading as rich as they are now(the only actual difference in my carb is a 1 step higher main jet. I had run my bike before with this same main jet while tuning it for stage1). Anyways, the info does talk of too high a gap and fouling, misfiring, and poor economy and performance can occur. I reduced my gap to .035 from .040 and gonna see how the plugs look after riding with no other changes to the tune. My 05 service manual say correct gap on the stock motor is .038-.043. Link to the info.. http://www.nightrider.com/biketech/t...k_plug_gap.htm
do you have any oil dripping from the air filter? It may be that you are overfilled with oil and the excess being pump out of the vents is going back into the top end of your engine and turning the plugs darker. Try running your oil level a bit lower and see if the darker plugs don't go away. I just did the 95"/9.4:1 compression/cams bla bla bla and I used a jet drill to open up the main jet---190 by .003" (not up to a 195). My exhaust is just a bit darker than cocoa and the plugs look fine, and I'm still getting 43 mpg and the bike hauls butt with NO carb farts--just a thought----jack
I didn't read it, but I know that too much gap causes problems and so does too little gap. Too small of a gap and the spark is quick and weak, too big and the ignition system labors and misfires can result.
The only way to truly find what gap works best for you is to experiment just like you're doing. I'm not sure I would have gone .005 in one shot but, what the hey? Plugs are cheap.
Used to do this with carburated engines when one plug looked richer than the other; decrease the gap in the richer plug, something reasonable for that particular plug, and maybe increase the leaner plugs just a little if it was too lean. It did work to even out way the plugs were burning.
Don't know the physics / science behind it but suspected that the smalled distance would actually produce a stronger spark, richer environment would, more saturated, more sure to fire. Larger gap would mean more distance, slightly weaker spark but more environment to pass through so better chance of ignition.
checked the oil and the hot level is just fine, maybe a couple ounces low actually. I did just check the plugs after about an hour of riding and they are quite a bit cleaner than before. Engine performs great. So as it stands I will leave it at .035 for now as I think this did help. Both my plugs look to be real close to even. The front is darker than the rear though. Also I have NGK irridiums in there/ se wires, and a Daytona twin tech ignition module with the timing slope advance over stock. The NGK's could be a lower temp plug than stock, so this could also explain the extra carbon buildup and need for a little smaller gap than a stock plug. One thing I do get is oil through the vents(does not drip from the filter). I run the engine hard while riding, so it stands to reason I get it in the vents regularly.
Okay, went and read it. Nightrider, huh?
Not sure they completely understand what's going on in there. Superchargers and turbo-superchargers send hurricane force air just screaming into the combustion chamber. That's their job. It's what they do. That much wind really can extinguish a spark, just like blowing out a candle. Which is why I run a high-energy ignition system on my supercharged car. And .045 gap.
NO2? Meh. It releases its oxygen molecules at a certain temperature (540 degrees?) and isn't screaming into the combustion chamber like a runaway freight train.
But I don't disagree with you experimenting with your plug gap. I guess I don't have to know why something works, just that it does.
I don't have OCD. Besides, the letters aren't arranged properly. It should be ODC.
The higher the psi the greater the resistance between spark plug gap. I can see needing a narrower gap or higher voltage ignition with a hotter build in theory and some cases real world application.
The whole turbos/superchargers blowing the electic arc out is well a bunch of BS. They do however raise compression psi over same build natural aspirated which does raise resistance between the gap which is the real science.
Bingo; There is no wind in the cylinder when the piston is where the plug fires, it is just around 38* btdc up at speed and the increased pressure is what causes the increased resistence to firing the plug. I believe the entire problem would be solved with stock plugs installed. I could be wrong, of course, but I've been doing engines for 45+ years and the old plug testers checked the firing ability of a plug with increased psi when looking into the sight gauge, remember them???
