2002 dyna super glide
Old May 20, 2010 | 07:51 PM
sknydpr's Avatar
sknydpr
Stage III
Default 2002 dyna super glide
I just purchased a 2002 FXR dyna super glide. Does anyone know what the FXR means? The bike came with a HD badlander seat. WOW! can't ride on that thing very long. I'm looking for a seat that will fit on the bike. I see alot of seats for dyna wide glides. Will they fit the super glide? Will a sportster seat fit?
Old May 20, 2010 | 08:37 PM
ecvjohnny's Avatar
ecvjohnny
I think you mean FXD. You got a pic?
Old May 20, 2010 | 11:53 PM
SURFOR Chop's Avatar
SURFOR Chop
Sportster seat will not fit ... stick with the seats made for your model and years ....
I am sporting a seat from an '09 Street Bob on my '05 Super Glide ... doesn't fit perfect, but good enough for me ....
Guess what I'm saying is you might be able to 'color outside the lines a little with the year (or might not be so lucky); but, you definitely can't use a seat from another whole model line like Sportster, Softail, V-Rod or Touring ....
R/
'Chop
Old May 21, 2010 | 12:36 AM
Bear_925's Avatar
Bear_925
F=big twin, X=sport chasis R=rubber mounted engine...to the best of my knowledge.
Old May 21, 2010 | 05:45 PM
SURFOR Chop
Can't argue with your logic, but ....
The MoCo stopped using that Alfa designation when they introduced the "Dyna" line-up ... previously, the Super Glides were designated FXR ... up until '92 I believe .....
I stand by my advice WRT seats ... the other models' seat pans are different shape/size ....
On my bike, the frame beneath the seat is about 1/2" longer than the later models, so when the tab at the rear of the seat is bolted to the fender mount, the front tab that slides under the tank mount is a little short and at a slightly greater angle ... I just went ahead and bolted it down in the rear and used a zip tie to hold the front in place ... works okay and not noticeable ....
R/
'Chop
Old May 21, 2010 | 06:57 PM
sknydpr's Avatar
sknydpr
Stage III
BEAR 925 is that a oem seat? Looks alot better than mine. And thanks fot the help on the FXR question.
Old May 21, 2010 | 06:58 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Here's a breakdown of the VIN, 1HD1GH=FXD
GJ=FXDX
GL=FXDXT
GD=FXDL
GE=FXDWG
If your VIN has the GH the you have the FXD Superglide. A good strong bike. The FXR is the fore runner to the FXD and had one of the best frames HD ever made.
Old May 21, 2010 | 09:42 PM
Bear_925's Avatar
Bear_925
Hey Sknydpr, yeah it is the oem stock single seat with a passenger pillon, was the cheapest way to go at the time.
Looks like you have the badlander harley seat, i've been told those aren't the most comfortable but I think they look more streamlined.
98glider
EVO
Jul 11, 2018 03:25 PM
luckycpd
Sep 1, 2015 03:31 PM
ZEKE83
Jul 23, 2014 07:28 AM
roy micks
May 1, 2014 07:50 PM
Rfc
May 30, 2012 10:06 AM
