Horn relocation
Old May 21, 2010 | 07:24 PM
Foxster's Avatar
Foxster
I moved mine to the gap behind the battery box facing the rear cylinder, which is just the right size to take it and there is an unused threaded hole on the back of battery box you can bolt a home-made Z-bracket to.
Old May 21, 2010 | 07:30 PM
harleyflyboy's Avatar
harleyflyboy
Originally Posted by tomt
I think this is what your looking for. I relocated the horn to the front.
Okay where did you get that rig, part numbers etc.?
Old May 21, 2010 | 09:09 PM
ppowell's Avatar
ppowell
2nd Gear
Where did you get the skull horn cover (PN/Website)?
Old May 22, 2010 | 09:00 AM
tomt's Avatar
tomt
On the new Rocker the horn is in the front on the frame below the lower tree.
You can purchase the whole assembly and bracket from Harley.
It is way to much $$$. So I got an after market one for about $28.00. It came in chrome. I painted the cover black and attached a Sportster, Willie G Skull timing cover to it.
The Rocker horns cover, comes in chrome. It can be painted black or can be powder coated because it is made of metal. The after market one I have is plastic and had that fake chrome, that's why I painted it.
This project was very easy to do. Had to add more length to the wires going to the horn. I also made a piece to fit where the Cow Bell was.
Old May 22, 2010 | 12:42 PM
pcbunn's Avatar
pcbunn
Ok I'm stupid, what's the best way to remove the rubber horn mount from the side after moving the horn?
Old May 22, 2010 | 12:50 PM
Foxster's Avatar
Foxster
A wrench on the back and then grip the rubber wheel with a big pair of pliers or a small pipe wrench.
Old May 22, 2010 | 03:06 PM
Derv's Avatar
Derv
Mine lives down here now, scroll about half way down page in link
http://www.oldgitbiker.pwp.blueyonde...ide_page_2.htm
Derv
Old May 22, 2010 | 07:16 PM
FXD-raw's Avatar
FXD-raw
pcbunn,
'Tomt' has pictures that show what I have, with the exception of the nifty and expensive chrome cover. The 'foxster' described exactly what I was telling you. It's a bitch to get that rubber mount hardware off. I used vice grips and that worked for me. I think the key is to just rip with your strength once to get it loose, otherwise you may destroy the rubber around the piece. I just came back to check the post now. Let me know if there is anything else, but it seems like everyone has the details covered.
raybagger1
Apr 18, 2017 12:49 PM
mydogfarted
Apr 16, 2016 07:35 AM
user 46092
Jul 3, 2015 08:30 PM
LOTL
May 16, 2011 04:46 PM
strtarrow
Jul 5, 2010 12:16 PM
