Big spark plug problem!!!
Old May 27, 2010 | 09:07 AM
1plumr1's Avatar
1plumr1
HD shop manual says anti seize and gives torque values. I think that dispels the dry plug torque theory. Personally, if I had to chase threads or do any work that might allow metal shavings into the cylinder, I would pull the heads (simple process, really). A scored cylinder wall will cost a lot more than the time to pull the head. Just my 2 pennies (but I am ****).
Old May 27, 2010 | 09:14 AM
jstreet0204's Avatar
jstreet0204
Originally Posted by lennyb3us
I thought of that with the oil on the threads I put a cheap set of stock harley plugs in there to run for a bit then I'll replace them with the double platinum ones. Thanks for the tip though
Did you use oil or grease? You should have used grease. Grease is thick and will stay inside the grooves of the chaser and catch the shavings. Oil would just run down into the chamber.
Old May 27, 2010 | 09:15 AM
Grendel4's Avatar
Grendel4
Yeah, it 'could' happen. But the odds of a couple shavings, a few 1000ths in size, causing any damage before they get blown out the exhaust valve are pretty slim.
And if it does happen (not real likely but possible) and then you have to pull the head(s)?
Rusty Axle
Shovelhead
Apr 28, 2019 09:49 PM
dwebber
Engine Mechanical Topics
Jun 19, 2010 02:42 PM
Fox
Aug 7, 2007 06:47 PM
grippper293
Jul 1, 2007 11:13 AM
Shift_4lo
Mar 11, 2006 03:37 PM
