Two 97 FXDL Lowrider Questions
Old May 30, 2010 | 04:13 PM
Broken Leg Rider's Avatar
Broken Leg Rider
Default Two 97 FXDL Lowrider Questions
Traded my 79 Ironhead finally. For a 97 Lowrider with 9,960 miles. Took the Dyna out for the first long run today. She is a nice little power house.
First: Trying to shut off the fuel and run her till she quits, doesn't seem I can find the right position on the petcock. There is no "Off" position. There is "Reserve" on top, "Fuel" on the bottom and looks like --F forward. So, I put the blade forward and ran her for several minutes. No cut off. Does it take a long time for this one? My 79 Sportster would shut off in about two minutes, if that long.
Also, I find that the front brake lever will not travel all the way out when released, leaving the brake light on. It travels to pinch my fingers when braking and does feel soft. It will finally bite though. Ordinarily I would think this means air in the line but I have heard that the caliper pistons get fouled and might not travel on these bikes. Any advice here?
Thanks. I love the bike, and I can't believe I have had so many others but not an FXD before - much less an FXDL.
Old Jun 1, 2010 | 11:57 AM
GasserNorm's Avatar
GasserNorm
I believe the "new" petcocks are vacuum operated. There is no off like the good ol days.
Old Jun 1, 2010 | 09:41 PM
Broken Leg Rider
The 97 still had a carb. I tried it again with the blade forward and she quit her slow chug chug after 3 minutes. So it must be a big bowl -. The Ethanol in the gas these days will clog up a carb pretty fast if you leave it with the petcock on. Takes much longer to clog over time if you run it "dry" when you know you wont be running her for a while.
The dealership flushed the forward brake lines and solved that problem. They tell me you should not leave DOT 5 (silicon based) brake fluid for more than two years between replacements. It will absorb water from the air in that time. The water will corrode your internal parts and deteriorate braking performance.
Old Jun 2, 2010 | 06:44 AM
GasserNorm's Avatar
GasserNorm
Thats good info to know. I was under the impression that since the petcock was vacuum operated it wouldn't shut off when "closed". Since I was told that a while back I never tried to run my carb dry, but I will now.
WilllyD
Jun 17, 2017 11:29 AM
brad75raiders
EVO
Apr 10, 2017 05:34 AM
junglejoe
Apr 9, 2014 04:47 AM
dmftoy1
Jun 1, 2009 11:43 AM
oldfrtbkr
Jun 13, 2006 11:42 PM
