Torque spec needed
Old Jun 1, 2010 | 07:25 PM
05DYNALOW's Avatar
05DYNALOW
Question Torque spec needed
Does anyone have the torque spec. for the exhaust flange nuts on an 05 Dyna?? Not something I want to strip!
Old Jun 1, 2010 | 08:22 PM
BIGDADI's Avatar
BIGDADI
100-120 inch pounds or 10 foot pounds
well that's for the 09 sorry just read the 05 wrong before I posted.
Old Jun 1, 2010 | 08:34 PM
Taddeoeg's Avatar
Taddeoeg
Hmmm. I have manuals for both the 2000 and the 2007 and both say 60-80 in-lbs. That's around 5 ft-lbs but I've never seen a torque wrench that could go that low and be accurate. Better off with an in-lb model.
Old Jun 1, 2010 | 08:35 PM
Inspector 12's Avatar
Inspector 12
The information in my manual is for 2010 touring models but I found it interesting that not only do they have the spec but a tightening sequence. Manual says to tighten the bottom nut to 9 - 18 inch pound and then tighten the top nut to 100 - 120 inch pounds then tighten the bottom one to 100 - 120 inch pounds. I chose to tighten mine to 110 inch pounds.
I also found that after the install of the new exhaust system (D&D Boss Fatcat 2-1) that I had to re-torque the nuts after 500 miles.
Old Jun 1, 2010 | 08:51 PM
BIGDADI's Avatar
BIGDADI
agreed and agreed, everything you said is what my manual says and what I had to do after the initial torquing.
but the op is looking for 05 specs
Old Jun 4, 2010 | 11:21 PM
05DYNALOW's Avatar
05DYNALOW
Thanks for the info. I'm hoping to take out some vibration out of my pegs. Dealer checked the motor mounts and said they were fine. Also did an engine alignment and the vibes seem worse than before to me. We'll see.
felix27
Jun 22, 2016 11:34 PM
swansonj6
Jun 6, 2016 01:13 PM
Sliver1
Jan 17, 2014 03:12 PM
KEYBEAR
Sep 16, 2013 10:02 PM
Bigtreedog
Jun 2, 2007 07:45 PM
