Rake change
Old Jun 3, 2010 | 07:35 PM
TL03fxdl's Avatar
TL03fxdl
The attached document is missing the drawings (figures) referred to in the text, because that's all that I could copy and post. I suggest searching (like Google) and reading up on 'rake and trail' calculations for more info...
File Type: txt
Old Jun 3, 2010 | 08:48 PM
Robottom's Avatar
Robottom
Like the look, don't think I'd go there because I like the handling on a stock FB way too much, but you have my curiosity up.
Question since WG trees are being mentioned.
Where is the rake in WG trees? Are the tubes through at an angle, ie: not perpendicular to the trees, or is it how trees attach to the neck?
Old Jun 3, 2010 | 09:01 PM
FATBOB.'s Avatar
FATBOB.
i went on the harley site and check the rake on the fatbob which is 29
and check the wide glide which is 34...road a wide glide and was very happy
with the handle..if i want to run real hard, i take out my cbr1000rr 2006...
if the price is right i will try it..i was told that if i change only the triple tree
on my bike,with stock fork, it would drop the front end 1/2 inch.i was told i would
see a very small diffence....that from a chopper builder...waiting for the price...
Old Jun 3, 2010 | 09:02 PM
08fxdf43202's Avatar
08fxdf43202
Originally Posted by SURFOR Chop
... apparently so ... just look at it ...!
Of course your stock front end or even wide glide won't look like that Hawg Halter front end with the upper fork tube covers that extend above the triple trees .... that's probably $1,800 - $2,500 easily ... looks great though (especially with the $600 rear fender) ....
R/'Chop
I thought those were inverted fork tubes...
I think the best part of this bike's looks is how the bottom of the frame is parallel with the earth, the rear doesn't look lowered...
which leads me to think...
Why not slide the fork tubes up the trees 1-1.5" and see how it looks & handles?
That would cost... let me think???... $0!
Old Jun 3, 2010 | 09:15 PM
jstreet0204's Avatar
jstreet0204
You might want to do some more research on rake and trail before buying anything. Wide glides only have 3 degrees in the trees. The other two is from rake in the neck, which corrects the trail. Get your trail off too much and it may be unstable at speed.
Old Jun 3, 2010 | 09:28 PM
ghostrider69's Avatar
ghostrider69
Fatbob, just remember that the WideGlide rode nice because it utilizes a raked neck and tree. Not just trees. Ever heard of Death Wobble? Read through this link.
http://www.rbracing-rsr.com/rakeandtrail.html
Live2rideUtah
Aug 4, 2015 08:55 AM
45js45
Mar 6, 2012 06:27 PM
dtech
Apr 27, 2011 06:56 PM
fxrsteve
EVO
Sep 13, 2010 12:05 PM
skull rider
Jun 23, 2008 11:43 PM
