Rake change
Old Jun 1, 2010 | 07:46 PM
FATBOB.'s Avatar
FATBOB.
Default Rake change
ThinKing about changing the rank on my fatbob...
It is a 29 and thinking going to a 34...i know i will
lose some handling , it will change the look...am i
right or the only thing i need to change is my triple
tree...if someone knows.i like the rank on this fatbob..
Thanks for your time...
Old Jun 1, 2010 | 07:57 PM
mikeault's Avatar
mikeault
Do some more research before you pick up trees. There's a little geometry involved to make sure you have the right tube length/angle etc. I don't really know the ins and outs, but I know there are some... ins and outs.
Old Jun 3, 2010 | 07:36 AM
08fxdf43202's Avatar
08fxdf43202
...am i
Why?
Is 'the way it looks' really worth losing the handling on a Fat Bob?
Old Jun 3, 2010 | 08:08 AM
8541hog's Avatar
8541hog
If setup properly that small of a change should not make a big difference to the average rider. If you are a twisty monster then maybe not a great idea. Basically you are talking about putting a Wide Glide front end on her, and I know my WG handles twisties just fine.
Not sure of the tube length on the FB, but you may want to extend a couple inches.
Old Jun 3, 2010 | 09:15 AM
2007fxdc's Avatar
2007fxdc
According to my indy, 5 degrees is the max you should go on a dyna and you WILL change the handling on the bike and cause the front wheel to want to lay over easier especially at slower speeds. It's doable, however. Just go out and get used to it before you start riding it like you always did before. He recommended no more than a 3 degree increase to get the least amount of handling difference and still get a different look. I think if I were going 5 degrees, I'd go ahead and swap the whole front end out for a WG setup, though.
Old Jun 3, 2010 | 01:31 PM
ghostrider69's Avatar
ghostrider69
What will swapping out the entire front end accomplish?
Old Jun 3, 2010 | 01:46 PM
2007fxdc's Avatar
2007fxdc
I would think it would better assure the right geometry with the right length tubes, etc. But, I'll take back what I said. I wouldn't do the 5 degrees period. I'd leave it alone or get some 3 degree trees and be done with it. I think the FB's unique front end looks good as it is.
Old Jun 3, 2010 | 01:57 PM
ghostrider69
If I owned a FatBob and wanted to go to 34 degrees I would buy an aftermarket set of 5 degree trees because the stock WideGlide trees only have about 2 degrees built into them. I would then purchase WideGlide tubes because they are longer than other FXD models and use my stock lowers so that I could still have my dual front brakes. But like 2007fxdc said I would not go 5 degrees simply for safety purposes. I installed 3 degree aftermarket WideGlide trees on my bike and love the look and can't tell any difference in handling.
Old Jun 3, 2010 | 02:07 PM
2007fxdc's Avatar
2007fxdc
Good point Ghost, I didn't think about the brakes. Yeh, you'd want to keep your lowers or figure out how to fab the new ones to fit the brakes. And, would have fender issues to deal with as well? Still, might be cheaper to get a good deal on a whole WG front end and just use the parts needed. All that said, I still wouldn't do more than 3 degrees based on the conversation with my indy.
Old Jun 3, 2010 | 02:08 PM
SURFOR Chop's Avatar
SURFOR Chop
Originally Posted by 08fxdf43202
Why?
... apparently so ... just look at it ...!
Of course your stock front end or even wide glide won't look like that Hawg Halter front end with the upper fork tube covers that extend above the triple trees .... that's probably $1,800 - $2,500 easily ... looks great though (especially with the $600 rear fender) ....
R/
'Chop
