Plastic cover
Old Jun 6, 2010 | 03:58 PM
Gooch's Avatar
Gooch
Default Plastic cover
I have an 05 wideglide and found a plastic rectangle shape piece laying in front of the rear tire. It appears to be from a matching hole in the rear fender. Question is does it press in from the outside or inside.
Thanks.
Old Jun 7, 2010 | 02:38 PM
icufltrn's Avatar
icufltrn
you can push it back in from inside the fender (between the wheel and fender) it is the access for the service loop.
Old Jun 7, 2010 | 02:49 PM
VsTheWorld's Avatar
VsTheWorld
http://www.explodingdog.com/dumbpict51/goodpie.gif
Old Jun 7, 2010 | 03:12 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
+1...
If you have a look at this parts diagram p/n 99 is mounted like icufltrn stated above:
Originally Posted by VsTheWorld
it should go up under the taillight - i have no idea how they stay in there, not much holding it in place
...matter of fact i have to check mine after I had to resolder the turn signals over the weekend - i wish that piece had a more positive locking mechanism like a screw or better snap
Are you sure it is mounted under the taillight, Jim?
Old Jun 7, 2010 | 05:02 PM
VsTheWorld's Avatar
VsTheWorld
JefferiesHD1
May 17, 2015 07:59 PM
Sticky4
Nov 22, 2012 11:04 PM
x1rider
Apr 23, 2012 06:58 AM
mojojones
Jul 9, 2009 02:13 PM
Karsten
Aug 6, 2008 10:58 PM
