I installed a SE stage I A/C today on my 2010 SG. The instructions started with remove the Maxi-fuse and ended with replacing it. It said to check the owners manual for the procedure.
Well I looked through the owners manual and the service manual for said Maxi-fuse. Unable to locate.
I made a wild guess that it might be the ecm fuse that maybe by pulling it and replacing it, the ecm would relearn with the new a/c.
Thanks. In the instructions it had the registered emblem after it making one believe that it certainly would be called that.
Well, it is too late now. After everything was installed, I just had to go out and ride it. No harm was done. When I did the same thing last year on the Softail there was no such instructions about any fuse.
