Low Rider with V-Rod Front End
Old Jun 11, 2010 | 07:56 PM
lo-rider's Avatar
lo-rider
Default suspension
Originally Posted by Just Enough
Thanks all. My Low Rider is an 08 and the V-Rod front end is an 06, both are 49mm fork tubes so the swap is pretty straight forward. V-Rod front wheel, Brembos, discs, axle and spacers. Had to purchase an 11/16ths master cylinder for a Fat Bob, used stock take off brake lines from an 09 street glide touring bike.
This sure looks like a slick way to put dual disks on your Dyna. I can imagine that this provides an unimaginable improvement in braking.
Wondered if you are satisfied with suspension aspect, or if further modifications are necessary.
Good work.
Old Jun 11, 2010 | 08:03 PM
blackfatbob's Avatar
blackfatbob
great job man
Old Jun 11, 2010 | 08:20 PM
U-234's Avatar
U-234
That's thinking with your dipstick. Looks good.
Old Jun 11, 2010 | 08:37 PM
bikerlaw's Avatar
bikerlaw
Great mod. Thats something I never would have come up with. Looks nice too.
Old Jun 11, 2010 | 10:28 PM
Just Enough's Avatar
Just Enough
Good work.
The V-Rod damper rods have a little more rebound and compression damping than the Dyna. I swapped over my Ricor Intiminators inertial cartridge emulators and also the springs I had shortened from the Dyna forks to the V-Rod forks. The V-Rod front is more controlled than the Dyna was with the same mods. In the rear I have Ohlins. I have re-valved dirt bike suspensions for many years so I had to play with the Dyna front end spring rate and oil level for a while before I was satisfied. Everything I did with the Dyna front forks worked better with the V-Rod forks. I machined some extension sleeves to lengthen the travel of the V-Rod forks from 3 inches to 4 inches to match the stock Dyna travel. I am running my oil level at 4 inches from the top measured without springs or emulators and the forks completely compressed.
raanselmi
Apr 26, 2017 06:48 AM
hd4evr2008
VRSC Models
Feb 23, 2015 01:56 PM
waltz4
May 5, 2014 04:12 PM
littlejohn1
Softail Pictures
Apr 3, 2013 08:57 PM
BadBobOk
Aug 26, 2008 07:17 AM
