Lowering Question???
Old Jun 13, 2010 | 09:03 AM
tazman509's Avatar
tazman509
Thanks for all the responses. I put the rear on last night and it looks ok. Seems to handle decent. I do agree with you all and think it will be better to go ahead and lower the front as well. I read somewhere about changing to different fork oil which improved the ride a bit. It does not appear that there will be any issues with bottoming and hitting the fender. I put the initial setting on 3.
Old Jun 13, 2010 | 09:21 AM
dynarule's Avatar
dynarule
I lowered just the rear of mine,even lower than the pic in my sig, and I havnt had any problems at all with how it handle's and it looks realy good, but you loose some ride comfort on rough roads and your spine will let you know when you hit a good dip in the road. One thing that will help is changing the fork oil to the Screaming Eagle heavy. I strongly advise this.
Old Jun 13, 2010 | 10:42 AM
tazman509's Avatar
tazman509
Thanks dynarule for the info. Since I do not have a motorcycle jack I will probably just take it in to the shop. I will have them add the SE heavy fork oil as well. I am sure once the front is lowered I will have to grind down the stand a little as well. I hate paying for work that is fairly easy to do but it is sure nice to drop it off before work and pick it up when I get off. Increases my riding time!
Old Jun 13, 2010 | 01:08 PM
Luwise's Avatar
Luwise
I lowered the rear on my FXD 1 1/2" with Progressive Shocks and road it a while before lowering the front 2". With the rear lowered I didn't notice much of a differance, but when I installed the Progressive "drop In" front springs it seemed like the bike handled about 300 % better. Everyone I talked to advised to lower both the front and rear to achieve the best ride and handling. I'm glad I took their advice.
Old Jun 16, 2010 | 05:52 PM
tazman509's Avatar
tazman509
Got the front springs installed yesterday. It is much much better. Love the new look. Ride is not too bad and the handling is good. Thanks for all the input.
Old Jun 16, 2010 | 05:57 PM
HDTech74's Avatar
HDTech74
what about cornering clearance.
my fxd is low enough I scrape my exhaust.
Old Jun 16, 2010 | 06:05 PM
tazman509's Avatar
tazman509
No issues so far. Have not pushed it too hard though.
Mikula
May 25, 2014 04:46 PM
Bobby_Lee
Jun 17, 2013 04:11 PM
92Softail
Apr 16, 2011 08:40 PM
gunslinger8
Jun 26, 2010 12:43 PM
AZJD
Jan 7, 2008 02:20 PM
