Lowering Question???
Old Jun 12, 2010 | 01:26 PM
tazman509's Avatar
tazman509
Default Lowering Question???
I am getting ready to install a slammer kit on my FXDF. Has anyone lowered just the rear and not the front? Dealer tells me it is better and it will ride better. Any input is appreciated. Trying to decide if I go with his input or lower the front as well. Also has anyone had any issues with it bottoming and messing up the wiring under the fender? Trying to avoid a reroute of the wires.
Old Jun 12, 2010 | 03:38 PM
SC-Longhair's Avatar
SC-Longhair
Your bike will look like one of those mid 80's Dodge K cars with 8 people in the back seat. If that's the look you're going for....go for it. Otherwise, I'd suggest lowering the front and rear to keep with symmetry and geometry.
Old Jun 12, 2010 | 05:02 PM
streetbobkid's Avatar
streetbobkid
if you have the kit for the front lower it too, having just the back lowered throws off the geometry, therefore changing the way the bike handles, you will lose some ground clearance but if you like to lean it your going to drag pegs, exhaust, etc.
Old Jun 12, 2010 | 06:07 PM
thetroll's Avatar
thetroll
Do both ends...
Old Jun 12, 2010 | 06:18 PM
lo-rider's Avatar
lo-rider
Default simple
Originally Posted by tazman509
I am getting ready to install a slammer kit on my FXDF. Has anyone lowered just the rear and not the front? Dealer tells me it is better and it will ride better. Any input is appreciated...
Once you have the rear lowered the answer will be obvious.
Old Jun 12, 2010 | 08:03 PM
08fxdf43202's Avatar
08fxdf43202
Just slide the forks up the trees an inch.
Old Jun 12, 2010 | 08:05 PM
B-EZ's Avatar
B-EZ
another vote for both
Old Jun 12, 2010 | 08:09 PM
Guest
Guest
Posts: n/a
Me, too. You can get away with having the front a hair lower than the rear, but not so much the other way around.
Old Jun 12, 2010 | 08:10 PM
jaybird708's Avatar
jaybird708
deff do both i have the slammer kit on my bike..
Old Jun 12, 2010 | 08:11 PM
DXrider's Avatar
DXrider
It will not handle better. It might be easier to move around in your driveway, but it definatly won't handle better.
