Where did it all go?
Pugs - +1 on what Coldcase said, Aplogies if it sound like I (we) were having a go at you earlier, but you MUST - especially on a Harley - check your oil level frequently, it goes with ownership!
If you still had a quart of oil in there then my guess is that your motor will be fine, so don;t worry about it anymore. Oil lights will err on the side of caution usualy and come on well before any damage is caused. Having said that it's always good practice to stop and get some oil in there as soon as the light comes on
Just for information there are two usual ways in which oil lights work. 1) by oil pressure - the pressure is monitored by a sensor and the light will come on when the pressure drops below a certain level. 2) The oil level in the sump or tank is measured. I had this system on my Yamamha V.Max, but some design goon had put the level sensor at the front of the sump,. Everytime I accelerated hard (and the V.Max accellerated VERY hard) the oil lightt came on. The first time it happened I was really quite worried, until the guys on the forum put me right! The oil pick-up to the pump was at the rear of the sump though so no damage was ever casued.
I'm not sure which system is used on the Harley motors (maybe someone would like to enighten me?) but as they use an oil tank my guess would be it's a level sensor?
DON'T FORGET .......CHECK YOUR OIL!
Derv
With that said, I hope all is well with the bike and things are back to normal.
now I'm pretty sure pugs will be on the checking the bike stuff. LOL
Once it's a habit, you don't really miss the 2 seconds it takes.
