dyna rear turn signal relocation
Old Jul 25, 2010 | 01:29 PM
Bone11B's Avatar
Bone11B
they dont have them for 06' later dynas will the early ones still fit?
Old Jul 25, 2010 | 01:36 PM
Brewtality's Avatar
Brewtality
I mounted a light bar from a touring model.
Old Jul 25, 2010 | 01:51 PM
pcbunn's Avatar
pcbunn
What I want to know is "how do you see down the road"?, you must be one big guy!
Old Jul 25, 2010 | 02:15 PM
83 fxdg 90's Avatar
83 fxdg 90
remove them
Old Jul 25, 2010 | 02:18 PM
JRK5892's Avatar
JRK5892
here is how i did mine, cheap like 10 bucks from a sport bike flush mounts
look under my struts, they are LED
then i also wired turn sigs into my tail light, took a bit of wiring and led work with resisters, but the last 2 on each tip of the ends of the lights flash for turns as well as one other one i added in there
Old Jul 25, 2010 | 03:25 PM
Jarhead08's Avatar
Jarhead08
Check out jokermachine.com they have some sweet led tight fitting lights.
Old Oct 5, 2012 | 10:06 AM
Rob Vegas's Avatar
Rob Vegas
6th Gear
Default bars
how tall are your handle bars?
Originally Posted by JaronB
Then I went to a touring light bar!! A little grinding to fit flush and good to go.
Old Jan 8, 2016 | 06:21 PM
Fxdbluebill's Avatar
Fxdbluebill
6th Gear
jaronB thats exactly what i want to do. mount my original blinkers while keeping the back support. howd ya do it?
Old Jan 8, 2016 | 09:12 PM
JaronB's Avatar
JaronB
My local ACE hardware had some chrome spacers. I wish I could remember what size, but it's been so long ago. I know it took me a couple trips to get it right. Then used the factory brass strips on the inside of the fender, not the ones that come with the detachable kit that you can screw into. Bought the right size and length bolt into the rear sigs from the inside of the fender. I'm been running the touring bar since 2010 I believe. I wish I had all the spacers and bolts to be exact for the first set up, but I gave them to my dad back in the day.
Hopefully this all makes sense.
Old Jul 16, 2016 | 08:57 PM
Ntomlin08's Avatar
Ntomlin08
6th Gear
JaronB or Brewtality, how did you guys wire in the touring bar to the old signal housing? I'm gonna be picking up a touring bar soon and wasn't sure the best way to go about wiring it up. Any direction would be appreciated.
jayzee75
Mar 22, 2012 04:11 PM
CapeSalyers
Jul 10, 2010 10:46 AM
DaddyKnuck
Oct 19, 2008 07:29 PM
WARG
Sep 9, 2008 11:15 PM
Bobberino
Feb 21, 2008 11:06 AM
