help required Please
Old Jun 28, 2010 | 05:11 PM
sideshow bob's Avatar
sideshow bob
Default help required Please
I took a 120 mile trip to Wales over the weekend with no problems on my 2006 Street bob, spent the night and when I tried to start my ride next morning It just splutters and fires a few times but will not actually start. I had it brought home on a truck and I have tried the coil, plugs, checked all the connections. There are no error codes showing so I have discounted any problems with the sensors. The only thing left to check are the fuel injectors (but I think they would show up in the error codes) or may be the the fuel itself is contaminated.
I don't want to have to take it to the stealers so any help would be appreciated.
Thanks
Old Jun 28, 2010 | 10:20 PM
cactusred's Avatar
cactusred
I really don't you got a problem with your injectors friend. You say it lights a couple times and sputters and dies, so obviously you got starter/ignition working, do you hear the fuel pump kick on when you push the run/off switch to run, does your fuel gauge work. Have you made any recent mods/upgrades to say the handlebars/switches/neck/turnsignal area?
I'm betting your fuel pump is not running/ or is intermittantly running, especially since you have no codes. If that's the case there is a fuse for fuel pump I believe and then there is a relay, it's one of the big ones, called a system relay that ties up your fuel pump/fuel gauge, fuel system period, I had to replace it on my streetbob 06 for similiar issues to yours.
Hope that gets you in the right direction...
Kate58
15
Dec 24, 2017 02:31 PM
jmd897
Jun 8, 2017 08:31 AM
just plain john
Aug 28, 2013 09:08 PM
Digger1785
May 21, 2013 01:33 PM
wwalton259
Apr 24, 2011 07:10 AM
