street bob vibration
Old Jul 3, 2010 | 02:29 PM
uer 84038's Avatar
uer 84038
Default street bob vibration
my fxdb vibrates a lot in the lower rpm's and it smooths out at higher rpm's thus each gear has a sweet spot. is this normal? my 883 was far better and i expected this to be even better but not so.
Old Jul 3, 2010 | 04:48 PM
FitZoner's Avatar
FitZoner
Default yup it is normal
That is what these rubber mounted stallions do. It'll vibrate in your seat and hands when your RPM is too low and it will vibrate in your feet when the RPMs are too high. Keep it in the sweet spot and its all good.
Old Jul 3, 2010 | 07:35 PM
Supergo's Avatar
Supergo
Keep her near redline, that will cure those vibrations.
Old Jul 3, 2010 | 09:25 PM
Dynamic's Avatar
Dynamic
Perhaps check the primary chain tension and final drive belt tension. Check with someone of your weight sitting on the bike, not on the stand.
Old Jul 3, 2010 | 09:43 PM
uer 84038's Avatar
uer 84038
final drive belt is a bit loose.
MMH
Jul 6, 2018 12:34 AM
twilliams
21
Nov 11, 2015 07:20 AM
gorgenzola
Jul 25, 2013 04:00 PM
doc1972
Feb 21, 2010 08:15 PM
hws3
Feb 13, 2009 03:25 PM
