01 Wide Glide Engine Oil Leak...please help
Old Jul 3, 2010 | 09:53 PM
zwrightwideglide's Avatar
zwrightwideglide
6th Gear
Default 01 Wide Glide Engine Oil Leak...please help
2001 wide glide. just replaced the primary, shift shaft seal, main shaft (tranny) seal, and str jackshaft seal along with any other or rings in the area. I am still having a small leak collecting on the end of the engine oil drain plug and a little bit on the end of the primary drain screw. In addition, my engine oil is on the lower end. I run synthetic. Please advise where the engine oil could be coming from and possible fixes.Thanks much, Zach
Old Jul 3, 2010 | 10:53 PM
8541hog's Avatar
8541hog
If you have an o-ring on the drain plugs, do not crank them down as tight as you can, it can distort the o-ring and cause a leak.
Old Jul 4, 2010 | 03:28 PM
zwrightwideglide
6th Gear
Where are some other areas that ENGINE OIL can leak from other than the drain plug. I am trying to narrow this down as much as possible. Again thanks for your replies.
Old Jul 9, 2010 | 03:50 PM
zwrightwideglide
6th Gear
FOUND OUT IT WAS THE MAINSHAFT AGAIN, i was wrong it was leaking primary fluid, engine oil was fine...yay all fixed up and good to go.
HoolyNI
Oct 30, 2013 03:38 PM
HARLEY57PAN
Oil Archive (no new posts)
Apr 23, 2013 04:55 PM
GrumpyBear
Mar 22, 2013 09:43 PM
Bingee
Jun 21, 2012 02:30 PM
2Shakes
Exhaust System Topics
Apr 11, 2009 10:12 AM
