wide glide front end
Old Jul 27, 2010 | 02:42 AM
hitmanforhire1's Avatar
hitmanforhire1
Stage I
Default wide glide front end
First let me apologize if this question is in the wrong place im new here need to get use to this ok so my question is i have a 1998 dyna lowrider but want to change the front end to a wide glide front end with a 16in front wheel is there any limitations to which front ends i can use. thank you for any help you can give me.
Old Jul 27, 2010 | 06:54 AM
FastHarley's Avatar
FastHarley
Former Sponsor
I have done a few of them. The 49 mm wideglide should be considered as well but there is not a lot of used ones for sale. If changing the forks are done for looks only than any style will do. If you wish a performance upgrade such as braking than look at a twin calliper mounting should be considered as well. Do your homework first without spending a dime.
Old Jul 27, 2010 | 08:17 AM
roofer's Avatar
roofer
For a 98 just make sure you get a front end from an evo that way brake calipers are the same
hooptygoo
Apr 13, 2016 12:17 AM
apetterez
Mar 2, 2015 08:33 AM
deedee4150
May 28, 2012 08:31 PM
wydeglyde98
Apr 6, 2008 06:01 PM
tomtwix
Sep 30, 2007 02:36 PM
