Should it take a competent Tech to Swap out Pipes, Intake and Drop in a Programmed PC V? I've found a local guy I might use, I just want to be forearmed with some knowledge, I'd rather not get billed 5 hours for a 3 hour job.
I swapped my pipes in an hour and would expect the same for a tech. The PC was already in my bike but I can't imagine more than an hour to route wires, disconnect O2 sensors, and download a map.
Ah, yes it is an easy DIY, problem is I have a bit of a disability. I can ride fine.... Short version of a Long Story, It is difficult to kneel or bend even for short periods (moments) . I've got a local guy that offered to do it.... didn't yet discuss the rate, I just wanted to get a Handle on time needed.
Sorry to hear, Jon. If you have the space, put the money you'd spend on labor towards a lift table. You can raise your bike up to a comfortable working level. Or, you can help keep those small businesses alive and well.
By the way, what part of Northern Jersey? I grew up in Hawthorne. Still visit once or twice a year.
Anything under 3 hours would be a fair quote to do all 3. I did mine at different times but I just did all 3 on a buddies Rocker a few months ago and probally took 3 to 4 hours taking my time. The PC install took a little longer on the Rocker as well because you have to remove the rear fender along with some other stuff on it.
