replacing front caliper hardware
Old Aug 3, 2010 | 12:38 PM
rdondes's Avatar
rdondes
Default SAE and Metric
Originally Posted by bbqbrisket
I thought Harley used SAE ????
You need to get the Harley-Davidson "Parts Catalog" for your bike. Many fasteners are metric. See your Harley dealer or go through www.harleydavidson.com
Old Aug 3, 2010 | 02:39 PM
bagman1's Avatar
bagman1
Originally Posted by 8541hog
Any bolt can come loose if not installed properly,
I have to stop writing stuff before I have my morning coffee. By coming loose I mean the lower caliper mounting bolt that you can get in chrome (non HD) does not have a shoulder on the bolt, it is threaded all the way to the head. You need to have a shouldered bolt going thru the fork leg in order for the caliper not to move while braking. This is what I meant by being loose.
Old Aug 3, 2010 | 02:43 PM
8541hog's Avatar
8541hog
Aah..You mean the bolt has a shank.
Old Aug 3, 2010 | 02:55 PM
SC-Longhair's Avatar
SC-Longhair
Mostly they do but since the forks are japanese (showa), it's all metric.
Fork cap = 35mm hex
damper bolt = 12mm allen
axle caps (that hold axle to fork lower) = 5mm allen
caliper bolts = 10mm 12pt
Old Aug 3, 2010 | 03:13 PM
8541hog's Avatar
8541hog
Fork cap = 35mm hex
Not sure what year the OP's bike is since he didn't mention, but the sizes you posted are post 06, they are different pre 06. They changed when they went to 49 MM forks.
Old Aug 3, 2010 | 03:39 PM
SC-Longhair
Yes sir. Those are the sizes I deal with on my 49mm front end.
Isn't your front end 41mm? I'm interested to know what size the major bolts and such are, just for knowledge sake.
Old Aug 3, 2010 | 03:42 PM
SC-Longhair
Harley-Davidson Chrome Caliper Hardware Kit. 44473-02A
List Price: $33.95
Our Price: $30.95
You Save $3.00
Availability: Usually Ships in 24 to 72 Hours
Product Code: 44473-02A Qty:
Description Harley-Davidson Chrome Caliper Hardware Kit
Chrome-plated hardware is a great finishing touch to Chrome Brake Calipers. This kit replaces the Original Equipment black 12-point bolts, pad pins and bleeder screw on a single caliper.
Fits '00-'07 models (except SpringerŽ front caliper, '04-later XL, '06-later FX SoftailŽ rear calipers and '06-later VRSC™ models).
By the description, it doesn't matter if its 41mm or 49mm.
Old Aug 3, 2010 | 04:10 PM
8541hog's Avatar
8541hog
I think the big difference is the fork cap and the damper bolt in the bottom of the forks, as I recall mine was 6mm or maybe 8 mm, not 12 mm, and I think my top cap was 1 3/8", but not certain on that.
Old Aug 3, 2010 | 04:15 PM
8541hog's Avatar
8541hog
Oh and the calipers are completely different, they were redesigned sometime, in looking at Matt's Fat Bob, nothing like the rear caliper on mine, didn't really look at his front caliper.
Bloozmann
Aug 18, 2014 05:21 PM
Cliff-AZ
Mar 23, 2014 11:41 PM
HighLiner
Aug 1, 2011 10:03 PM
Cityfyrman
Wheels/Tires
Jan 29, 2009 07:22 PM
jsbridgew
Jan 12, 2008 12:26 PM
