Question about Alignment
Old Aug 6, 2010 | 04:29 PM
Guitarfinder's Avatar
Guitarfinder
Default Question about Alignment
I noticed when I look down at my bars when I am riding perfectly straight they do not look centered. I'm I crazy? it looks like the bar clamp is crooked...
Old Aug 6, 2010 | 04:51 PM
HBomb74's Avatar
HBomb74
i was thinking that same thing about my 2010 fat bob
Old Aug 6, 2010 | 05:22 PM
Guitarfinder
So maybe I'm not crazy?
Old Aug 6, 2010 | 05:37 PM
srshaw's Avatar
srshaw
This could be due to the camber in the road (the way it is raised in the middle). I would expect if you drive on the right side, a bike will tend to steer to the right with the bars straight trying to go down the hill, so you probably have to steer to the left to keep going straight.
Old Aug 6, 2010 | 06:23 PM
Phrogman's Avatar
Phrogman
Could be a couple of things. Depending mostly on bars and risers. The stock dampers for the risers are a soft compound of rubber. Because of this they can allow the risers to "tweak" a bit. To find if this is the cause, go out and turn your bars past the fork stop to see if they center back up. If they do, you can replace the dampers with polyurethane ones that are stiffer but still reduce vibes.
Another factor can be if your handlebar clamp is not a single piece. If you essentially have two separate risers, they can be twisted just enough to where the bars are at an angle on the top triple tree instead of straight across.
On my Fat Bob with the 6" pull back risers (two separate risers, no solid clamp) I have the same problem. I looked at it, loosened, adjusted, tightened, overtorqued, anything I could think of to figure it out and then I realized that when I was picking the bike up off the kickstand I was twisting the bars to the right. They were off-centered to the right as well. So, I put them on the left fork stop and tweaked them a bit and sure enough they straightened right out. Now I lift the bike before I rotate the forks to avoid the problem until I feel like changing the riser dampers.
Old Aug 7, 2010 | 01:08 PM
Guitarfinder
Thanks guys I will check it out today before my ride, Much appreciated!!!
Altereddezignz
Milwaukee Eight (M8)
Aug 28, 2018 05:01 PM
Tarkus60
Nov 12, 2016 09:58 PM
rrambo
Apr 27, 2011 09:32 AM
GfromAlberta
Aug 3, 2010 07:24 AM
priceamp
Jun 20, 2006 01:07 AM
